Got a new toy!
Old Jan 26, 2008 | 05:45 PM
  #16
streetbad's Avatar
Originally Posted by 97WS6Pilot
The F1A is a work of art...If it is too loud for you, check out my PVC silencer I made on pg 2 of my Cardomain site.
What is inside of your pvc silencer??
Old Jan 26, 2008 | 06:54 PM
  #17
97WS6Pilot's Avatar
Its got fiberglass insulation similar to a glass pack muffler. Its a flow through design so it does not cause any restriction I got the PVC pipes and insulation from Lowes.
Old Feb 17, 2008 | 02:40 PM
  #18
Funkybird's Avatar
Time for an update. Im about done, I just need my radiator hoses and to do a few finishing touches and it will be driveable
Heres a few pics for your enjoyment
Old Feb 17, 2008 | 04:58 PM
  #19
97WS6Pilot's Avatar
Very professional install. Looks good.
Old Feb 17, 2008 | 05:42 PM
  #20
Funkybird's Avatar
Thanks man!
Old Feb 17, 2008 | 05:46 PM
  #21
c0rey's Avatar
Got a part number on the radiator? Anxoius to see how you do your hoses keep the pics coming.
Old Feb 17, 2008 | 08:57 PM
  #22
Funkybird's Avatar
The radiator/fan setup is from ofi. I'm supposed to get the hoses tomorrow so i'll let you know how that goes.
Old Feb 27, 2008 | 12:02 PM
  #23
96SilverRam's Avatar
Your setup looks great, I'm also interested to see how the hoses look when finished ( that looks absolutely cavernous with the radiator tucked under the support ) I have a question for all the 93-97 T/A guys, where are you putting the HCM (headlight control module) that normally sits in the drivers front headlight area. Every FI 93-97 T/A shows the inlet pipe going right thru the hole that the HCM covers. I have never seen where people put the HCM module after an FI install. Can you post some pics of where yours is placed, it would help me out alot....
Great looking combo...
Old Feb 27, 2008 | 05:46 PM
  #24
Funkybird's Avatar
Thanks for the compliments! I have that tucked up out of site with double sided tape, i'll see if I can get some pics.
I took the car out last night for the first time since the 6 speed swap and all the new stuff and took some video so i'll see if I can get it up.
Old Feb 27, 2008 | 06:13 PM
  #25
1982z28with18s's Avatar
Nice! What fans are those, I hope they flow enough air being pushers.
Old Feb 27, 2008 | 07:10 PM
  #26
SiDeWaYZz28's Avatar
What bracket are you using?A f1 cant fit on a disc bracket right?
Old Feb 27, 2008 | 08:32 PM
  #27
Funkybird's Avatar
They are spals. The fans and radiator are from ofi, its what they use in their kits.
THe bracket is the same for a d1sc. Had to grind the corner off my block and ditch the sway bar cuz I coulnd't install the inlet with the sway bar on
Old Feb 27, 2008 | 10:31 PM
  #28
That would be great if you could get some pics of where you mounted the (HCM module). I would really appreciate it ! Can you tell me how much OFI charged you for the radiator, spal fans, overflow canister ? I'm assuming you purchased it as a kit for the LT1 car. Does it have the neccessary filler neck and how is the access, did OFI install a position for the CTS (coolant temp sensor, my car is a 96 WS6) that normally sits on the passenger side of the radiator about 6 inches down ? The reason I'm asking the questions on the OFI radiator package, I'm going to do the same deal and would like to know if there is anything missing or strange that will not allow me to hook up the factory connectors and fittings. I want to have a clean OEM look when I'm done
Once again, that pic looking through the radiator at the F1 just makes me sick with envy Get the video up
Old Feb 28, 2008 | 12:17 AM
  #29
GreasyB's Avatar
Looks like a nice set up your putting together.... I'm jelous
Old Feb 28, 2008 | 01:27 AM
  #30
The SRZ's Avatar
You sure you can't get an inlet on there? I'm sure the F1A is the same size as the F1 and I got it on mine w/ the sway bar. Oh, did you have fun putting that belt on? LOL That's thing is a nightmare but I've got the hang of it now.
