Good of the shelf blower cams
Old Feb 2, 2007 | 10:14 AM
xxsaint69x's Avatar
What are my choices? Lookin for something bigger then my CC305, but i dont want to have ANY cam surge. It will be going into a 383 with AFR 227 heads and 18 psi or so
Old Feb 2, 2007 | 10:28 AM
Kredz28's Avatar
18 psi from what? Blower?
http://cmotorsports.com/engine/lt1-l...ft-design.html
Old Feb 2, 2007 | 01:11 PM
Birdie2000's Avatar
Comp high-lift 224/236 used to be real popular.
Old Feb 2, 2007 | 02:22 PM
Kredz28's Avatar
I too am going with that cam, the 224 236 114 lsa...its being installed as we speak, mines the lower lift one .536" int and .555" exh..
Old Feb 2, 2007 | 02:26 PM
Kredz28's Avatar
What do you guys think the difference in hp is between the low lift and high lift cam? Not hijacking or anything!
Old Feb 2, 2007 | 02:48 PM
xxsaint69x's Avatar
wahts the lift on it?
Old Feb 2, 2007 | 05:44 PM
BMAN'S SCZ's Avatar
I run a custom ground 224/236 .573/.579 on 115 in my 383 and passed emissions here in CT.
Old Feb 2, 2007 | 05:49 PM
Schurters LT1's Avatar
get a custom..trust me on this......you will leave 30+rwhp on the table with an off the self cam....
Old Feb 2, 2007 | 08:28 PM
xxsaint69x's Avatar
i doubt it....after reading bunch of threads i think i might just stay with my cc305
Old Feb 2, 2007 | 10:41 PM
I don't....if your going to put all this money into the top end why not match it right with a cam ?
it's a blower car so any cam will make power....but why not make more ????
Old Feb 3, 2007 | 08:24 PM
VK's Avatar
VK
Like stated already, blower cams are made for a reason. They don't make a world of different in all applications, but they do make a difference and they cost the same as any other custom cam. So the question is why not?
Old Feb 4, 2007 | 10:08 AM
JohnnyPappis's Avatar
I agree with that point custom cams in these apps are the way to go you wont regret haveing a cam built for your apps
Old Feb 6, 2007 | 08:59 AM
xxsaint69x's Avatar
decided to go with TS-224XH 224/236 duration, .605"/.622", 114lsa
With my Rockers the lift will be 623/622.
Heads are AFR 227 flow 308/210 @ 600 lift, and 313/229 at .700
Hopefully that cam will take better advantage of that then CC305.
Good choice?
Old Feb 6, 2007 | 09:38 AM
Kredz28's Avatar
Yea thats a WAY better choice than a 305...That cam will take advantage of your bad-*** heads.
Old Feb 6, 2007 | 10:21 AM
RealQuick's Avatar
You tell em' Jeremy.
