Is this a good or bad cam for a turbocharged set-up
Old Mar 26, 2006 | 03:09 PM
detroit1994z28's Avatar
Just wondering if this would be a good cam for a turbocharged set-up ?232/240 at .050 .595/.608 lift with a 115 lope separation
Old Mar 29, 2006 | 11:33 AM
canbaufo's Avatar
Re: Is this a good or bad cam for a turbocharged set-up
I doubt it. I think that's too much exhaust bias. Experts can chime in ....
Old Mar 29, 2006 | 12:32 PM
RealQuick's Avatar
The more and more I play with an engine sim. software I found online, I notice that the cam specs dont play a huge part on power/tq peak numbers with turbo setups, rather they affect spool time, peak tq rpm and peak hp rpm. I compared a 219/219 112 cam to a 224/236 114 cam and results were very similar. I have inputed about 30 cam combos and for my own personal vehicle...
That cam will be fine for you IMO.
Old Mar 29, 2006 | 12:43 PM
RealQuick's Avatar
By the way, hee is a screen shot of a 383ci turbo combo with cam you are looking at buying and a LPE cam:
Last results was the 219/219 .560/.560 112LSA cam
and
Current results was the 232/240 .595/.608 115LSA
There isnt a huge amount of difference between them.
Old Mar 29, 2006 | 03:22 PM
viper03af's Avatar
you dont want overlap on turbo cam beacuse of the exhaust pressure. usally ~2x the amount of boost. so if you hold the exuast open to long the gas will push back into the chamber and can cause KR or just plane loss of power from a contaminated mixture
Old Mar 29, 2006 | 07:19 PM
RealQuick's Avatar
That is what people always have said. However, guys like engineermike and alot of ls1 guys are running blower split (10-12 between intake and exhuast) and are getting great results.
Jon
Old Mar 29, 2006 | 08:08 PM
viper03af's Avatar
Jon
some is okay but you don't want the exhaust valve haning open forever, plus it keeps the exhuast doing its job, spooling the turbo my cam has -12 over lap
HectorM52
Jul 30, 2017 11:46 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Amshnock
14
Jan 18, 2015 11:47 AM
chuyz28
Nov 25, 2014 11:14 PM
jim88iroc305
Aug 13, 2002 09:24 PM
