getting front off for meth kit???
Old Apr 16, 2009 | 07:00 PM
ss#1230's Avatar
i know a lot of you guys have pulled the front "facia" off to get a fmic on.
are there any tips or tricks to it? which fasteners do i need to pull off? all i need to do is pull my windshield washer tank out....
thanks,
Jeremy
Old Apr 16, 2009 | 08:15 PM
jay_rich's Avatar
Pull it off for a FMIC or a meth kit? A meth kit wont require pulling the facia as it is only a pump and container...
Jay
Old Apr 17, 2009 | 12:30 AM
ss#1230's Avatar
as my original post states; i want to pull out the windshield washer fluid reservoir. i want to use it for my tank instead of trying find a place to mount the tank that comes with the meth kit. the supplied tank is too small, yet big enough to be a pain to find a place to mount.
do you know a way of getting at the washer fluid tank without going through the front?
Jeremy
Old Apr 17, 2009 | 01:48 AM
MikeGyver's Avatar
It's straight forward but takes a little while. Kind of a pain getting to some of the nuts on the sides where the bumper cover bolts to the fenders. I used a right angle socket drive on my cordless drill and zipped off all the little bolts along the bottom (10mm?).
You can probably just undo the bottom half or something and pull it out w/o removing the whole dam thing.
Old Apr 17, 2009 | 01:53 AM
ss#1230's Avatar
that's what im hoping will happen.....
i was wondering about the area in front of the fender. ill dig in there and see if i can pull it out the bottom. it also seems kinda tight just under the headlights.
thanks,
Jeremy
Old Apr 17, 2009 | 04:13 AM
MikeGyver's Avatar
There's also a metal tab on the bumper cover that screws in to the car near the headlights, so don't forget that (if it's even an issue).
Old Apr 17, 2009 | 12:58 PM
ss#1230's Avatar
thanks, got it off already.
by the way, your fmic looks bad ***! although ricers have them as a badge of "coolness", when you see that on an american muscle car...you know it's all business!
Old Apr 20, 2009 | 08:36 AM
94ttrim's Avatar
mine was a pain to remove, then when i finally got it out i noticed it had a leak i never used it so didnt know. i just ended up putting the 3quart bottle that came with the kit were the old one sat.
Old Apr 20, 2009 | 09:38 AM
ford's Avatar
the most trouble i had getting mine off was with the bolts on the top side near the front that are "covered" with the plastic cap. the damn things would not turn at first and they seemed to never completely back out.
Glad you got yours sorted out though, i need to get pics of my fmic hidden behind the billet grill, it does a great job of not showing the fact the front even has a hole in it.
Old Apr 20, 2009 | 07:55 PM
ss#1230's Avatar
well, i mis-spoke when i said i got it off. i meant to say that i got it out. i ended up pulling the black piece out from the bottom, in front of the air dam and just dropped the tank out from the bottom...
i may post some pics of the kit after i get it on if anyone is interested in seeing it. i got the coolingmist kit from ebay.
Jun 6, 2015 08:27 AM
dbrockma
Feb 16, 2015 02:56 PM
CARiD
Feb 9, 2015 09:35 AM
Dec 4, 2014 11:56 AM
