gear ratio for boost
Mike , i dont understand your post. You say gear choice has nothing to do with boost and then you say that boosted cars trap high and have a low peak RPM. These issues can be addressed by changing the gear ratio, correct?
If Forced induction changes trap speed and peak rpm, then gear choice most definately has everything to do with boost in this instance. Hence the post title
It's VERY simple. A higher gear ratio means it's less stress on the engine. A lower is the opposite. Turbo cars can't use high gear ratios because there is too little resistance, causing the tires to spin. So then they switch to lower gear ratios, and trap high because of the power and length of the gears.
Are you kidding me..? Supras do so well on the highways because they have longer gears. Not only do you utilize all of the power, the lower gears add more stress on the engine, reducing lag. You DEFINITELY want lower gears with a big turbo. You want higher gears with a small turbo because you aren't making any power, just like NA.
Jul 4, 2005 05:00 PM
