Garrett turbo charger
Old Jun 29, 2004 | 10:52 AM
desertfox's Avatar
What do you think guys about the Garrett turbochargers? Is any way or worth to modify them to use on 94' z28? Does anybody use these turbos? If yes, wich one do you think is good.? How good they are? Reason I ask, I don't have 3K for supercharger, and these turbos around $500. I don't mind to make some modification to bolt it on.
Old Jun 29, 2004 | 11:12 AM
Geoff Chadwick's Avatar
There is a LOT required to get a turbocharger or supercharger on. Buying a $500 turbo may be fine, but most likely it will be small, depending on how much boost you want to run...
Superchargers are cheaper unless you can do a lot of fabrication yourself. Turbos sound cheap - but they nickle and dime you to death VERY fast.
Old Jun 29, 2004 | 12:51 PM
sleepybu's Avatar
yup
Old Jun 29, 2004 | 01:45 PM
JZ 97 SS 1500's Avatar
Garrett units are very nice, nothing wrong with them at all. Yes some can be had for about $500, but those are typically T04 series turbos which are typically to small for our motors.
Jose
Old Jun 29, 2004 | 03:32 PM
desertfox's Avatar
So Guys is any turbo, or supercharger available under 1k even with some modification to make it work on our engine? I can't beleive those toys so expensive. Any idea please let me know.
Old Jun 29, 2004 | 04:10 PM
You can find the turbo itself for under $1000...
Turbo $600
wastegate $250
blow off valve $179
intercooler $400
intercooler pipes $200
headers $1350
Then there's fuel and tune as well...
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
