Full port AI + 8lb Procharger
Old Aug 5, 2004 | 02:37 AM
  #16
Lisa33's Avatar
Re: Full port AI + 8lb Procharger
Im running mototron 60lbs high imppedance injectors and my stock FP regulator gives 50psi ??? (no vac) so i have set the injectorconstant to 65lbs.
At 570rwhp 5900rpm they are at 70% dutycycle....
stock fuellines, Walboro intankpump widh new wiring from the alternator, V-plus volt booster.
Tried lucas 42lbs before i installed the new wiring to the pump, FP at 58psi injectorconstant 49lbs and they hit 100% dutycycle and the fuelpressure dropped at the top....
Im very pleased widh the mototron injectors, idles perfect at 950rpm...
Old Aug 5, 2004 | 05:31 AM
  #17
ProchargedZ's Avatar
Any comments on the Seimens 57lb high impedence? or Seimens in general?
Old Aug 5, 2004 | 06:47 AM
  #18
IDOXLR8's Avatar
I honestly have never used the Sieman 57lb injectors but I will say overall that Sieman makes a great injector. I have used Siemans 55lb (low impedance injectors) and am currently using 83lb Sieman injectors. I would email Jack at Racetronix and see if he has any experience with the Sieman 57lb injectors.
oldschool
Feb 9, 2016 09:21 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
