Forced induction tuning question
Old Apr 8, 2013 | 09:29 PM
David94TA's Avatar
Do you guys modify the %TPS for WOT table so that the PCM goes into power enrichment sooner? If so, what values do you change and to what? Thanks.
Old Apr 11, 2013 | 05:22 PM
Kevin Blown 95 TA's Avatar
Re: Forced induction tuning question
I did change the under 4k part of that table to lower values, mostly because I have a 58 mm throttle body, so it makes more power at less throttle angle than if it had the stock 48. You need to consider when you are in boost, but still at part throttle, then figure out when/if you need to go into open loop and add fuel. You do this by logging a couple runs onto the interstate or do a couple roll ons. The way the table is stock, you would still be covered if you floored it, but it's just the odd case of part throttle and boost that you have to make sure that it gives you the fuel you need. Lower them too much and you'll just waste fuel. My values won't be correct for your application, so I can't help you there.
Old Apr 11, 2013 | 08:06 PM
David94TA's Avatar
OK, thanks
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 27, 2015 06:27 AM
ChrisFrez
Jan 18, 2015 08:05 AM
