Finding a vacuum/boost leak on a turbocharged car?
Old Nov 30, 2007 | 06:16 PM
meengreen 94z's Avatar
I've already tried using a smoke machine several times, with no luck. Spraying brake clean doesnt work on forced induction cars.
Im almost certain that their is a leak, what other methods are there to find a small leak(that possibly becomes exposed under boost)?
Old Nov 30, 2007 | 08:05 PM
GMRL's Avatar
Hook up an air tank to the outlet ducting from the turbo with a regulator. Set it to whatever PSI you run, maybe a bit higher and look around all the pipes for leaks, maybe dab some soapy water on all the connections and look for bubbles.
Red97LT1
9
Dec 17, 2014 06:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
blac94Z
Nov 28, 2014 01:53 PM
USAirman93
Nov 24, 2014 03:37 PM
x7x7
Aug 15, 2002 06:49 PM
