Finally figured out what happened at the LTx Shootout
Old Jun 22, 2008 | 02:50 PM
Ponyhntr's Avatar
For those of you that knew I hurt my car at the LTx Shootout, I have finally got the time to tear it apart.
For those that didn't know anything, to put it short and sweet, I ended up with lots of water in the oil before the first round of eliminations. I thought it was just a headgasket had blown. Well I got the heads off of it and both headgaskets are fine. Here is what I found after a second look. :thumbdown:
Look just above the piston on the cylinder wall.
I don't know what I'm going to do at this point, I have several different options. I just gotta weigh them all out. :???:
At least I know I can go 9-second speeds (135 mph) non-intercooled and on 91 octane and not hurt the pistons or headgaskets.
Old Jun 22, 2008 | 06:29 PM
Boosted_Z28's Avatar
That's too bad Josh...sorry for your problem. What is the bore of your motor? I suppose the only way you may have caught that was to have the cylinders sonic tested before boring, but its not very practical. Nice MPH by the way!
Old Jun 22, 2008 | 07:47 PM
Ponyhntr's Avatar
It's only a .030" over motor, so I wouldn't have thought that I would have had a problem like that. It's only got about 1000 street (easy) miles, 12 dyno pulls and 3 track passes on it.
Old Jun 23, 2008 | 10:32 AM
Rice Killer87's Avatar
Thats ****ty man,I wouldnt have thought an iron block wouldve done that w/ that little run time and only 30 over.
Time to go block hunting,good look on a good find bro!
Old Jun 24, 2008 | 04:08 PM
87slyroc's Avatar
if you scrap the block i need a set of front and rear main caps???
C6LS3
Apr 15, 2015 09:50 AM
BMP Mike
Jan 7, 2015 11:12 AM
smokin25th
Jan 1, 2015 09:06 AM
madman69
Aug 18, 2002 03:58 PM
Dragonballz28
Jul 25, 2002 03:19 PM
