finally dyno'ed my car! ltx, s400, th400!
well after a long *** time it finally got dyno'ed!!!!!!!
final number were 670/598! NO meth, PUMP gas!
MOTOR
ltx 385
8.5 CR
LPE ported heads and custom ground cam
lt1 intake
colla crank
JE pistons
4 bolt splayed billet mains
head studs and cometic gaskets
IGNITION
stock comp
stock opti
msd coil
msd 6AL, TR7's @28
FUEL
duel walbro's
stock lines
60lbs injectors
aeromotive fpr
stock rails
DRIVE TRAIN
th400 RMVB with brake
3500 nitrous stall
s60, spool with 3.54 gear
TURBO (custom fab'ed by me)
twin logs with 2.5 merge
T6 s475 with 1.32 AR
tial 38mm gate and 50mm bov
a2a intercooler
5" dp exiting the front bumper
verticle radiator
this is on pump gas, timing was @20, 14 psi
http://www.youtube.com/watch?v=ZuzstNXH5Dk
MOTOR
ltx 385
8.5 CR
lt1 intake
colla crank
JE pistons
IGNITION
stock comp
stock opti
msd coil
msd 6AL, TR7's @28
FUEL
duel walbro's
stock lines
60lbs injectors
aeromotive fpr
stock rails
DRIVE TRAIN
3500 nitrous stall
a2a intercooler
verticle radiator
Nice! Im hoping for around the same numbers...just dyno'd mine on pump gas no meth on 8psi and got 583/491
T6 turbos are great! hahah
I wanna see pics of the setup or ban!! lol
Jay
Jay
ill get some pics up of it!
Very comparable, mine is a 74mm t6 flanged. It has a .96A/R hot/.95 A/R cold. I see boost at about 3800rpm.
I havent been to the track as I am in the middle of getting my 9 inch built, and cage going in it. I will be running it on the 21st!
Also we do alot of (closed road) racing :P, we have a 1/4mile mapped out and My car is trapping 135mph as it sits. I raced a Caged 347 Procharged 8psi Notch with a cage and murdered him.
Jay
Jay
what impedence converter is everyone running?
very nice man. you can get 79# high imp. injectors, plenty for what your s400 will put out
i had av ery similar setup to yours (near identical turbo to jay rich's) and was only putting out about 70 hp more with 4 more psi (spiked towards the end to 22 total) but i think its due to log style headers
Do you mind sharing the cam specs? Wondering how it is compaired to my custom comp.
Mine is a 230/236, .544/.555 114lsa (1.6rr)
Also I now know its not my cam...watching the full vid and seeing your dyno graph it looks like mine, damn laggy T6 turbos lol
Jay
Jay
nice numbers 4SFEDZ , that looks like it will get the job done
yeah....i would like to know as well
what happend? I mean.. you have run a T70,TV75...nitrous...six speeds, th400s...4l60s
1000rwhp 10 second cars..... I cant keep up
