Felpro 1142
Re: Felpro 1142
Not knowing Felpro's gaskets by heart, are you referring to the Intake gasket? You may want to do a little reaseach. I don't know the exact gasket my motor shop used on my setup, but it was some kind of less dense gasket with the 3M sealent on it. The 3M sealent is key for boosted motors. But again, I am not too knowledgeable on it, so more digging will need to be done.
If it is a different gasket, then I apologize for giving info on something you were not asking about.
Re: Felpro 1142
Originally Posted by xxsaint69x
is the felpro 1142 the gasket i need for my 383?
going to run 20psi so thats the reason for steping up to the MLS.
Re: Felpro 1142
guys i am talking about a new felpro head gasket which is made out of multi layer steel....here is the link
https://www.jegs.com/webapp/wcs/stor...tegoryId=29251
Re: Felpro 1142
I have a set for my motor, but I'm also not going to run 20psi. I think a lot of guys running high boost use Cometic gaskets. If I ever get my motor together and in the car I'll let you know how well they work. If they blow out the first week then I'd say don't buy them
Re: Felpro 1142
Originally Posted by camarossguy2
I use a new stock and know of serveral high boosters that do to. if i remember correctly, the felpro one is paper or cardboard and seemed cheezy.
Thought you were talkin intakes
Head gaskets i use 1074s
Re: Felpro 1142
if they are better and will work..id like em too. they are even a little bit thicker...i wanna hear anything i can with these....so far im planning on 1074's but if these are a little better Ill go with them. Im only going to run 10-14psi
Re: Felpro 1142
Re: Felpro 1142
Bill
