f1 sc
Old Nov 13, 2003 | 03:26 PM
Mike383LT1's Avatar
f1 sc
any of you guys running a procharger f1 sc right now im running a d1sc have it maxxed out looking to see what has to be done to make it fit any info will help thanks
Old Nov 13, 2003 | 04:37 PM
rskrause's Avatar
Moderator
IDOXLR8 is running one, as am I. It fits ok. Here are the problems I encountered with it. Using a 12-rib belt, the fan shroud requred trimming modification. That was the only fit problem per se. But the intake ATI upplied was complete junk. I had to have custom solid intake fabbed up. Maks good boost but is very, very noisy.
Rich Krause
Old Nov 13, 2003 | 04:47 PM
Mike383LT1's Avatar
f1 sc
i know what you mean the one they supplied with my d1sc is junk does not fit did you by yours as a f1 kit or did you upgrade wanted to know if the f1 fit the d1sc brackets thanks
Old Nov 13, 2003 | 11:28 PM
TimbrSS's Avatar
You say that like its a bad thing.
Mike, you say you maxed out the D1SC. I'm curious as to how much boost and or power you were able to get out of it?
I called ATI a while ago to see about SC upgrades. IIRC, both the F1, and even the bigger F1R use the same bracket as the D1SC.
Old Nov 14, 2003 | 10:03 AM
mongse_1's Avatar
I'm sure the F1 would fit the D-series brackets, but not the F1R. That's a damn big blower.
Old Nov 14, 2003 | 10:13 AM
Mike383LT1's Avatar
d1sc
pullied for 18 lbs i see 12 on my gauge thinking of going to f 1 so i dont have to spin it so hard tried to dyno once could not hook it at 5000 rpm it put 477hp & 573 foot lbs to ground car didnt even break a sweat it present form it should put between 600-650 at the wheels just ordered a set of afr 220's in an attempt to get the car off race gas compresion was 10.5 to 1 new heads will get it down to 9.12 to 1 plus going to accel dfi 7
Old Nov 14, 2003 | 11:17 AM
IDOXLR8's Avatar
In order to get the F1 to fit properly I had to grind away on the block. Also the D1SC bracket and the F1 bracket are the same. I would highly reccommend contacting SD concepts about a spring loaded tensioner. The F1 is a night and day difference from the D1SC.
Old Nov 14, 2003 | 11:33 AM
Mike383LT1's Avatar
f1
thanks for the info
