A/F ratio ?
Old May 26, 2003 | 06:42 PM
GEES97TA's Avatar
A/F ratio ?
I get confused all of the time on this what is lean and what is rich...i know my car is running at 12.1 is that ok and is it rich/lean?
I was also told that running this way would clog up a cat if i had one is that true?
Old May 26, 2003 | 09:07 PM
96TurboTA's Avatar
14.7 is stoic, higher numerically is lean, lower numerically is rich. I'll let someone else decide if 12.1 is too rich.
Old May 26, 2003 | 10:09 PM
GEES97TA's Avatar
yeah whats weird is the tuner said when im crusing around my A/F is 14.7 but when i get into it , it goes to 12.1 to 12.2 how does it change is that the way he has it programed i know it was done on a dyno if that helps.
Old May 26, 2003 | 10:54 PM
ATMINF's Avatar
If your car is running a A/F of 12 underboost conditions it is running rich, but that is what you want under boost conditions. It sounds to me that you are okay. Under full Boost my A/F was at 11.7 to give you some comparision. Also it was at about 9-10 psi. As for clogging your cats, I would say since you car like most blown cars are not running in boost conditions all the time your cats will be fine for a long while. But don't forget that over time a cat does get"clogged" by just doing its job, in some cars it takes about 5 years and in others it takes longer. That is why in most cases where guys that put on a "off-road" pipe say that there car is running so much faster that it did with the cat on. I would venture to say that the car is probably a couple of years old and the cats were starting to get restrictive. Also if you were to put on a new hig flow cat I am sure it would flow great and it would also feel like the car got faster. Hope this helps.
Old May 26, 2003 | 11:01 PM
GEES97TA's Avatar
Thanks, i dont have a cat right now im thinking of getting one to cut down on the raspiness of my exhaust at 3000 rpm and up i hope that will help but doesnt hurt my RWHP #'sas for my A/F it was done on a wide band tune so i guess its ok
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
Henson071
Dec 30, 2015 09:55 PM
Z Power
Sep 19, 2015 11:19 PM
Henson071
Aug 4, 2015 09:32 AM
