Electric Clutch to disengage blower when not needed?
Old Feb 19, 2004 | 09:07 PM
hellostop's Avatar
Would it be possible to use an a/c electric clutch (maching needed) to connect and disconnect a blower when not needed?
Sorry if this has been hashed out already.
Old Feb 19, 2004 | 09:25 PM
Bud M's Avatar
kinda like Mel Gibson's car in Mad Max?
Old Feb 19, 2004 | 11:18 PM
97WS6SCharged's Avatar
You gotta love that movie. The great V8 interceptors.
I fail to see the point, if the blower isn't needed, just don't depress the gas enough to produce boost.
Old Feb 19, 2004 | 11:32 PM
engineermike's Avatar
Yeah, if you don't want boost, stay off the throttle.
Clutch = one more part to break. And with a supercharged car, we don't need any more complication than is absolutely necessary.
Also, a typical supercharger pulley is 2.75" - 3.33". The A/C clutches are about 4", so the blower would spin slow and build little boost.
Mike
Old Feb 20, 2004 | 12:42 AM
Maybe if you used an 8 or 9 inch crank pulley it would work.
Old Feb 20, 2004 | 08:31 AM
Sean94Z's Avatar
This same topic comes up once every 3 months.. do a search, it's been discussed in length here many times..
--Sean
Old Feb 21, 2004 | 10:21 AM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
LMAO at this topic.
Old Feb 21, 2004 | 10:39 AM
got_hp?'s Avatar
some people actually build real replicas of that car
check this one out
also, check out this other madmax movie car it has twin turbo's mounted above the hood, looks crazy
Old Feb 22, 2004 | 11:44 AM
Highlander's Avatar
I liked Knight Rider better
Old Feb 23, 2004 | 06:22 PM
86 Iroc HOTROD's Avatar
Doesn't fords super stallion use a clutch on its blower. Seems like the car is white blue and green, i've seen it at the auto fair in charlotte. I think that clutch was relatively small
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Jan 30, 2015 11:08 PM
sleeperZ96BT
Aug 4, 2002 06:52 PM
mjcent922
Jul 27, 2002 12:42 PM
