Dyno results from new exhaust.
From: I reached back like a pimp and smacked that LS1....
Previously my exhaust was 3.5 right off the turbo, back to a modified SLP two on the left muffler and tailpipes. (muffler was modified to have a 3.5 inlet). The wastegate pipe dumped into the downpipe about 10inches after the turbo.
My new exhaust is 3.5in downpipe until the trans crossmember where it steps up to 4 inch. From there it goes back to a Magnaflow muffler and mufflex style 4in single tip. The wastegate pipe runs along the downpipe until it steps up to 4 inch, then the wastegate pipe merges in.
It previously made 760rwhp 740rwtq @19psi.
Tonight it made 760rwhp 777rwtq @19psi.
It didn't pick up any peak horsepower, but it gained torque, and through the midrange it's up about 100 rwhp/tq. (I think because the larger exhaust allowed the turbo to spool faster).
I also (accidentally) made a run at 11 psi, and it did-
614rwhp 587rwtq.
Intake temps were starting out at around 65 degrees, and ending up at 140 by the end of the run. I think I might try a larger air/air intercooler, or make the switch to air/water.
614rwhp 587rwtq.
Originally posted by 97ChameleonTA
Great numbers! It's amazing to see the benefits of a change that most people would overlook.
BTW, what turbo are you running?
Marty
Marty
Pics are here if you're interested.-
http://www.chitownsyty.com/gallery/v...urboLt1&page=1
INTMD8,
Very nice indeed.
Can you tell me about your exhaust? I'd like to see some pictures if I could... I'm having trouble running my exhaust and would like to see how the experts do it.
Jesse
( jesselukeboyer@hotmail.com )
Very nice indeed.
Jesse
Re: Dyno results from new exhaust.
614rwhp 587rwtq.
614rwhp 587rwtq.
Obviously an S-trim isn't capable of 19 psi and 760 rwhp, but is interesting that at an equivalent boost level the S-trim did slightly better.
Am I missing something? Cam swap? Intake manifold swap?
Mike
Re: Re: Dyno results from new exhaust.
Originally posted by engineermike
I don't intend to start a turbo vs. supercharger argument, but didn't you make 634 rwhp with an S-trim Vortech at around 11 psi.
Mike
Mike
Thats some good power out of an Strim though.
Bill
Jesse_Boyer- Are you looking for pics of the turbo system, or the exhaust system? I don't have pics of the after-turbo exhaust yet, but I will soon.
engineermike- You are correct, the s-trim did 634rwhp at 12psi (and it was maxed out). The s-trim is more efficient at that lb per min/pressure ratio. Not to mention I had an air/water intercooler with the vortech which works much better on a dyno than air/air.
Re: Re: Re: Dyno results from new exhaust.
Originally posted by SMOKNZ
Might have been true, but I'd bet the area under the curve doesn't look the same.
Mike
Jesse
Ditto!
