Dripping oil from seals after boost
When ever I get into boost and shut the car off oil will drip from various seals, each which I have replaced more than once (intake, timing cover seals). I can't figure out how to make it stop. I run a PCV system with the line on the passenger VC run to a water/air seperator then to the inlet side of the turbo. I don't know if I should switch to an exhaust EVAC system or add a breather of some sort to keep the crank case pressure down. Any ideas would be great.
Just curious, and hopefully I didnt insult you
are you running just one pcv line to the catch can or two? what size hose? if its the stock stuff it might not be enough.
In essence, even with the change in your PCV system, you're still running a "closed system". This works fine when the intake manifold is seeing vacuum, but once the intake becomes pressurized, the PCV system does not work. Additionally, you are creating more crankcase pressure in boost than the motor sees under normal conditions and now the crankcase pressure has no where to go. SO, it starts to push against the seals. If you simply install a breather in the valve cover, it will more than likely just push oil out the breather while in boost and cause an oily mess under your hood. There are several threads regarding this topic going on right mow in this section. Search around a little and you will find there are some good options to correct this situation.
You could try just running the valvecover breather to catchcan and not run any line to the turbo. I dont think it will cure your problem though as it should work just like your current setup.
Nice looking setup. I actually dont see anything wrong with it since technically, the crankcase venting to the tube (with it going to the suction of the turbo) should see no boost. The boost is getting into the crankcase from somewhere... and it could be by the rings.
I know you run a similar system, are you running breathers of any sort?
1. Your current setup
2. Lines from VC to catchcan with a breather on the top of the catch can
3. Lines from VC to catchcan with no breather, line from catchcan to turbo inlet.
Some people use evac systems too. You may try adding a vent line on the driver's side VC and run it to the turbo too.
My car isnt up and running yet, but there have been 108943782348734819834 threads on ls1tech about this same issue and the typical setups to relieve crank case pressure are:
i am running moroso pcv exhaust vent kit...
I was talking to another member friday night and he mentioned that perhaps the boost in the crank case cant escape fast enough... possibly due to the single line and water/air seperator.
I would try adding a second line on the driver's side VC.
Any reason I should put one on both sides, or would both on the pass-side work?
