Downside to cog setup???
Old Dec 12, 2005 | 01:14 PM
  #16
CRZYTRN-92Z28's Avatar
Re: Downside to cog setup???
When I called ATI to get a few opinions they told me that the transmission on the D1SC couldn't handle the stress of a cog drive because it wont slip.
I think they're smoking crack. I run cogs on my D-1SC and it works perfectly. Boost is instantaneous and the charger is fine.
Old Dec 12, 2005 | 01:46 PM
  #17
Jason Short's Avatar
A M6 car is also going to be harder on a cog setup than an automatic car.
I would recommend the 12 rib setup w/SD Concepts tensioner. The ATI tensioner is garbage.
Old Dec 12, 2005 | 04:40 PM
  #18
Fastbird93's Avatar
That is what my initial plan is, and if that doesn't work it'll probably end up being a cog setup.
Old Dec 12, 2005 | 08:04 PM
  #19
EDS Z28's Avatar
Originally Posted by LittleRedZ
hows that? Crank drives the blower not othe way around. I snaped my snout early this year when the car was idling in the driveway with a 12 rib set up. Most of the time like i said earlier the Tension on the belt and missalignment of the belt is what does it. I noticed that with the12 rib set up you really dont have a belt choice the one that fits is very tight with no tension on it. It creates a PryBar effect kinda if you were to take a pry bar and put it on your crank and put constant pressure on it, the more you tighten the belt the more stress on the crank there is.
There is plenty of people that run very high boost on lt1s with stock hub, you just gotta be very carefull setting it up.
Did you have a keyed hub?
During my engine rebuild awhile back I noticed the stock LT1 crank snout was "gouged" a little bit due to the hub spinning. I just polished it up and been good ever since along with a billet steel keyed crank hub from ASP. How much damage was done when the snout broke?
Old Dec 13, 2005 | 12:08 AM
  #20
BADST95's Avatar
Thumbs up Re: Downside to cog setup???
Hmmmm... works fine for me.
Old Dec 13, 2005 | 06:54 AM
  #21
BADST95, your car is impressive What did you do to have good success with the ATI tensioner? I assume you are running the 12 rib setup with those boost figures.
Thanks, Jason
Old Dec 13, 2005 | 11:54 AM
  #22
LittleRedZ's Avatar
yes it was keyed. the motor only had 400 brake in miles, not fully broken in yet. No real damage was done car was idling at 900rpm i was in the car when i happend just a loud thump and i shut it off. Got a new crank "scat crank this time" and replaced all the bearings, rebalanced the motor. knock on wood 2k + miles 15+ track passes and no problems.
Old Dec 13, 2005 | 01:09 PM
  #23
BADST95's Avatar
Thanks, Jason
Thanks! I am using the 12 rib set up from ATI. I have seen several other cars use a 12 rib set up with 18 plus psi without any problems. I made sure that the pulley set up was aligned correctly. I had to machine the ATI aluminum spacer up to work with my balancer. The belt that I used is tight and I locked it down with the ATI tensioner... no slippage.
Old Dec 22, 2005 | 12:26 AM
  #24
1 DWN CAM's Avatar
The HSR 406 in December's issue of Super Chevy " The New Danger Mouse" (That I was apart of)Also uses a 12 rib pulley. When I was on the phone with procharger prior to the engine build, I also asked for a cog setup. They also discouraged me from the Cog, said it was a pain in the *ss for a "street car" that makes less than 1200hp. Go figure.
Old Dec 29, 2005 | 02:13 PM
  #25
tubby's Avatar
i run the F1 off a 12-rib see about 18# boost no sign of slippage on the data logger. still running the same bracket that came with the P1SC kit. car runs 9.20's with 1.25 60'. can't complain.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
