Difference in size of housing with Diff A/R?
What, if any, difference is there between the size turbine housing on a T series turbonetics turbo compared to the A/R ratio?
Or, if that didn't make sense, Are the external physical dimensions different for a T-series turbine housing with a A/R of .81 compared to a .96 A/R or even an !.0+ A/R and if they are different, how much and in what way?
I have googled my A$$ off, and searched this site, looking for this information but have had no luck.
Basically I want to know if my setup (with a Q trim .81 A/R turbine housing) will have to change if I go to a larger A/R on the turbine side.
Thanks.
Thanks.
Re: Difference in size of housing with Diff A/R?
Nothing will be changed..... The link below will explain what is changed when A/R is referenced.
http://www.forcedinductions.com/help.htm
JZ
JZ
