Custom Turbo kit, check it out!!!
Old May 28, 2003 | 11:23 PM
RallyredSS's Avatar
Talking Custom Turbo kit, check it out!!!
Got some pics of my turbo kit being built. Not very much so far, but there are good pics of the collector manifold. The turbo will sit in the place of the battery, not like the other kits.
http://www.4redlinemotorsports.com/current_projects.htm
scroll all the way to the bottom
Old May 29, 2003 | 12:15 PM
Guido's Avatar
Smile
Not bad! Keep us posted on the progress.
Old May 30, 2003 | 12:23 AM
stubbs's Avatar
Wow that is some shop, they do everything. Keep them pics a comin, me likey!!
Old May 30, 2003 | 12:45 AM
teamsleep13's Avatar
Looks sweet, do keep us posted.
Ya and that shop....mmmmm twin turbo vipers....
Hunter
Old May 30, 2003 | 04:07 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
how do you cut those nice notches in the primaries to match up to the log? jig notch?
Old May 30, 2003 | 07:35 AM
Sean94Z's Avatar
Are the turbo manifolds going to be open on both sides??? How does that work?
--No turbo knowledge Sean--
Old May 30, 2003 | 09:54 AM
got_hp?'s Avatar
Old May 30, 2003 | 12:25 PM
Sean,
I would assume the cross over enteres on the back, turbo mounts on the front.
Old May 30, 2003 | 01:49 PM
RallyredSS's Avatar
The primaries were cut by hand to fit up to the log. It's completely custom. Not all the primaries are the same length. We had to angle the log down to get past the ac compressor.
Old May 30, 2003 | 01:51 PM
RallyredSS's Avatar
The drivers side stock ported manifold will cross over with a 2.5" pipe to the passenger side turbo manifold around the back. The turbo will sit off of the up-pipe in place of the battery.
Old May 30, 2003 | 03:21 PM
got_hp?'s Avatar
why did you decided to go with a log manifold? ease of fabrication?
Old May 30, 2003 | 04:09 PM
so you just cut it with a plasma cutter by hand? thats how I did all mine.. and it sucked
Old May 30, 2003 | 09:05 PM
RallyredSS's Avatar
The log manifold was the easiest to fabricate.
Old Jun 2, 2003 | 09:50 PM
RallyredSS's Avatar
We cut the runners with a plasma cutter by hand and then ground them down with a dye grinder.
Old Jun 7, 2003 | 11:04 PM
RallyredSS's Avatar
Here is a link to the most recent up-pipe pics. Keep in mind that this is a mild steel prototype. We are sending this unit out to be professionally fabricated out of stainless steel.
