Copper head gaskets ?
Old Apr 9, 2010 | 02:16 AM
stephenpen's Avatar
I thinking of using a set of copper head gaskets but my block is not O-ringed. Will I have a problem with them leaking or will I have to tighten them all the time, SCE gaskets
Old Apr 9, 2010 | 08:44 AM
jsetzer's Avatar
All copper require an ORING, at least that is what one person told me. I learned the hard way. If in doubt always call the manufacturer.
When I was talking to them trying to figure out my issue I finally told the guy "Well maybe I should have o-ringed it, would that help?" I got a /facepalm over the phone.
Looks like some of them have compression rings in them. You need a way to seal the combustion chamber - either o rings or a gasket with a compression ring. Straight copper will not on a flat surface.
**Edited my response so it doesn't confuse anyone in the future looking for this info.
Old Apr 9, 2010 | 10:49 AM
stephenpen's Avatar
Thumbs down
I called SCE this morning. They have an ISC Titan gasket P/N S11064 that works well without O-rings. It has built in o-rings and seals around all the water jackets. But the one Jay rich has looks like the solid Pro copper gaskets.
Old Apr 9, 2010 | 02:22 PM
jsetzer's Avatar
I guess I stand corrected.
I did not have the sce - I had the Flatout rubber coated gaskets. Rubber coating dissapeared and they are the ones that I was told requried an oring.
Titans look like a better choice. After my coppers I went to Commetics and they sealed everywhere.
My point still stands though, always verify.
Old Apr 9, 2010 | 03:51 PM
RealQuick's Avatar
Just use gaskets made from Unobtainium and call it a day.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
