Considering buying a 96 z with a powerdyne
Old Jun 19, 2013 | 11:17 PM
stngh8r's Avatar
I have done some reading and I understand this kit is no longer. When did they stop making it?
The owner claims forged 368, lt4 heads, hot cam, edelbrock intake, 10psi, only a few passes but best of 11.4 with drag tires.
I have read that these usually don't make over 6psi?
What things do I need to be aware of or check for?
I think I will be getting the car pretty cheap too, which is the onl reason I started considering in the first place.
Thanks in advance
Old Jun 20, 2013 | 07:00 PM
Kevin Blown 95 TA's Avatar
Re: Considering buying a 96 z with a powerdyne
That time is pretty good for those modifications. Maybe see if he's got some time slips. A guy will usually keep his best time slips. And I don't get why a guy would build a forged 368 blower engine and use the hot cam unless he has a fairly high compression engine, then just added the blower later, and it's strong enough to hold together. It might be on the level, hard to tell from here. If you're skeptical, ask for build sheets and time slips and see what he comes up with. Is there any intercooling and modified ignition? And has the suspension been worked at all? What transmission is it and is the rear end still the spindly 10 bolt?
Old Jun 21, 2013 | 12:01 AM
stngh8r's Avatar
He said he has receipts and a few timeslips. He claims recently rebuilt 4l60 and unknown brand 2800 stall. He also claims 3.73 with a new posi in oe rearend.
Old Jun 21, 2013 | 12:06 AM
stngh8r's Avatar
Suspension I think is stock. No ignition mods visible. No intercooling.
Old Jun 21, 2013 | 04:57 PM
There's always the test drive
Old Jun 21, 2013 | 07:13 PM
97WS6SCharged's Avatar
Might want to ask him for receipts on the short block. 368 cid is an odd number for a production block, especially an LT1.
Old Jun 22, 2013 | 01:26 AM
stngh8r's Avatar
I thought 368 was odd too. He says he has lots of receipts. I'm going to look at it tomorrow, hopefully he will have enough receipts to make things clear. He seems amazingly clueless about cars.
Old Jun 22, 2013 | 01:28 AM
stngh8r's Avatar
I was hoping to get some feedback from fellow powerdyne users but I guess their aren't that many on here.
Old Jun 22, 2013 | 09:09 AM
That's never the kind of guy I trust when it comes to what a car can or can't do or what it has in it or how it was taken care of. Make sure to check it for blowby - take the oil fill cap out when it's idling and check for puffs of smoke.
Old Jun 22, 2013 | 06:25 PM
Powerdynes don't have the best record since it's a supercharger that is internally driven by a fiberglass belt instead of gears. They just don't hold up well once you start getting serious so most people just skip them and run Vortechs or Prochargers from the get go.
RUENUF
Mar 13, 2016 03:39 PM
warmeck
Jul 17, 2015 01:36 PM
filbielansk
Jun 15, 2015 05:28 PM
NewsBot
Jan 8, 2015 11:29 PM
