changing oil in paxton head unit...
Old Jun 19, 2004 | 12:59 PM
schpenxel's Avatar
I am trying to change the oil in my paxton supercharger but can't find any means to drain the old oil. I've searched thru paxton's website but find no useful help and the manual simply says "drain the oil" but doesn't really tell you if there is a drain plug or how y ou are suppose to drain it. I've of course looked for a drain plug but havent had much luck, the only bolts I can find appear to hold the entire unit together, any ideas?? Thanks.
Carson
Old Jun 19, 2004 | 02:04 PM
sleepy_z28's Avatar
The kit that I had (which I never installed and then sold) in the instructions is said to use the supplied suction ball with a tube on it to draw the oil up out through the dip stick tube. Then refill with X amount of oil.
Old Jun 19, 2004 | 02:06 PM
schpenxel's Avatar
k, ill rig up something and do that now...thanks!!
Highlander
Jan 12, 2020 02:13 PM
HectorM52
Jul 30, 2017 11:46 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
