Carb'd LT1 Turbo system question
I am doing some searching right now on what all is needed to swap over to the carb. I am gonna get the LT4 manifold and Opti block-off plate from SDPC. Most likely get a MSD HEI distributor from Summit. Do you think I should go with an ignition box? I am also still trying to figure out what all I need to do with the stock computer.
You'll probably want to leave the stock computer because it operates alot of things other than the engine, tying into the speedometer, HVAC, security, ABS, etc. . .
Mike
Well I am deleting the AC and take out the whole assembly, also plan on deleting the ABS. The car will mostly be a strip car with the occasional cruise. I am going with a Moser 9" and TH-400 trans with a brake.
I may buy a different box though, depending on money. Since it will be raced I figured I buy a 2-step.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Jul 4, 2005 05:00 PM
