Cant get more than 6# boost
Old Feb 15, 2003 | 03:57 PM
a327vette's Avatar
Just finished install of ati 8# intercooled kit. It will hit 8# for a second in 1st gear, but any other gear it wont go over 6#. I think the air filter I am using may holding it back, it is a moroso cone, about 5 in. long. I was going to use my old k&n, but it wouldn't fit with the mufflex piping and the maf.
Also, cant get the fp over about 70 psi. I am not running the ati inline, only a wabro 255lph intank. I dont think it is leaning out, but dont know for sure.
Just curious if anyone had any ideas, I am pretty new to forced air (about 5 hours )
Old Feb 15, 2003 | 04:42 PM
sscamaro387's Avatar
For starters...... Did u get it tuned?
Where did u tap into for the vacuum line? When u shut the car off, does the surge valve move freely?
Also r u getting belt slippage? Check the tension. cause since it's a new belt, it will stretch.
And last.... Check through out ur system to make sure there is no oil-blow-by.
Old Feb 16, 2003 | 03:31 PM
a327vette's Avatar
I havent had any tuning done, just kinda "feeling" it out at the moment.
I got my vacum source on the side of the intake where the egr sol. gets it's vacum.
The surge valve moves freely.
Not loosing much oil, but a little is blowing out the oil filler cap.
The belt seems tight enough. From what I have been told it needs to be as loose as possible as to not kill the blower bearings. I have about 1/2" movement in the belt.
One more question, this thing sounds like wholly hell at idle. The guy I got it from said it sounds normal. It is a p600b, sounds like bearing noise when the car is idling, but the case isnt getting hot, I guess it may be normal?
Stevie Whitley
Old Feb 16, 2003 | 03:45 PM
well, u should get it tuned. I got over 170 rwhp just cause of tuning.
And U should use ur brake booster for a vacuum source. that way u know u r getting vacuum.
Give keith a call at FFP, 530-775-0337 and order a vacuum tree, they are about $20 and u can connect ur surge valve line, and ur vac/boost gage to it.
And the bearing noise is normal, it's just the way ATI made them. but when u get to about 900 rpm's it goes away. and at 1700 rpms it has a beautiful whistle.
Old Feb 17, 2003 | 09:03 AM
a327vette's Avatar
What kind of setup do you have to get 170 hp out of tuning?
You dont need to use the brake booster line as a source, vacuum is vacuum. It all comes from the same place.
I had ran the car without the air flilter and with the bypass valve unhooked. I didn't have a boost gauge in it at the time, but it was much faster, which is why I thought it may be my air filter.
Old Feb 17, 2003 | 02:56 PM
everything in the SIG, but I was only at 4-5#'s before tuning. and i dynod at 354rwhp. and so I got a new pulley, and tuned it. then dynoed it again, and it was 477rwhp.
And I know vacuum is vacuum, but don't u think it would be better to get it direct from the source.
Also u should get a boost/vac gage, along with a F/P gage. thoughs are 2 of the most important gages, when u got a charger.
Old Feb 17, 2003 | 03:33 PM
a327vette's Avatar
the brake booster isn't the vacuum source, the engine is.
Old Feb 17, 2003 | 04:53 PM
i know, I meant if were to tap into the booster, u will definetly know if u have a vacuum problem.
Old Feb 18, 2003 | 11:27 AM
a327vette's Avatar
I have a fp gauge, and a vac/boost gauge. I am getting good vacuum.
Old Feb 18, 2003 | 04:04 PM
SMOKNZ's Avatar
If you have the "dryer hose" for the intake to the blower, it may be collapsing while you are building boost. You can make your own Vaccum tree from parts you can buy at a local hardware store for much cheaper than $20. If you are not running an FMU your fuel pressure isn't going to get that high. The Walboro intank pump is a great idea, and you shouldn't need an FMU with bigger injectors. Racetronics Walboro setup will support over 600 rwhp.
Bill
Old Feb 28, 2003 | 05:20 PM
FastGuyJR's Avatar
If it's spitting oil out of the dipsick plug, your crankcase isn't properly ventilated. Cap the vacuum connection on the throttle body or you're boosting where the oil goes, too. That's why it spits from the dipstick plug. Hope this helps.
JR
Old Mar 2, 2003 | 05:59 PM
a327vette's Avatar
I haven't had time to mess with it, I have been out of town. It is on a stock LT1 Camaro by the way.
Old Mar 2, 2003 | 07:07 PM
racr4jc's Avatar
8#s on a stock LT1 with no tuning, injectors, or FMU... Never had any experience with the motor, but i do have one sitting in the garage. It's sitting because of all the horror/scatter stories I hear about pressurizing on a stock bottom end...
Old Mar 3, 2003 | 07:45 AM
a327vette's Avatar
I am running an FMU
RUENUF
Mar 13, 2016 03:37 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
