Can you use long tube headers for a turbo setup?
Since the motor keeps pumping air, pressure in the system is controlled by the restriction (A/R) size. If you have an open exhaust you have no backpressure. If you have a 1/4" diameter tailpipe, you have alot of pressure. Since the A/R controls the pressure, a smaller A/R (tighter nozzle) increases exhaust speed. It's an extremely basic concept.
You're telling me speeding up fluid flow with pressure is a violation of physics?...
It almost sounds like you're confused by what I mean by re-introduce. What I mean by that is, you are re-introducing velocity (that normally might not be there in comparison to a front mount) by increasing pressure with the use of a smaller nozzle (A/R).
I was comparing my LT1 exhaust pipe length, to a typical front mounted LT1. Comparing it to something entirely different, would have made no sense whatsoever as far as delivering my point.
Yes, I may not have been clear enough. I was talking about intake air past the turbo, and exhaust past the turbo.
I'd like you to explain this me to (and Garrett).
i was talking about in front of the turbine (pre-turbo) that the smaller A/R compensates. I must have read what you typed wrong lol. The smaller A/R will increase exhaust speed AFTER it goes through the turbo - yes. The smaller AR compensates for the lack of flow pre-turbo, and creates more air post turbo. I agree with this.
What I thought you were saying was that the smaller A/R would increase velocity pre-turbo lol. Thats my bad man
