Boy, did I pick the wrong turbo cam
After months and months of waiting I finally got my engine put together and on they engine dyno. Its a 383 with 9:1 cr or so and 250cfm heads running a T76 ptrim with a 3.5" downpipe.
The cam is a 224/218 114LSA. Just to let you guys know with this cam the hp droped like a rock at 6000rpm Within 300 rpm I loose 40 hp or so.
On a conservative engine dyno we made 500hp @ 5700 and 520tq @4700 at 7 psi. It really liked 33 degrees of timing. We should be putting on the boost controller tonight or tomarrow night and crank up the boost to 15 and see what happens.
Re: Boy, did I pick the wrong turbo cam
thats a similar setup of what im building...that seems awefully low though, oh its only 7 psi.i was gonna say id have thought 600rwhp at 10 psi.at least.and u dont rev a stroker like that much past 6K!
Originally Posted by ddnspider
is this an lt or ls
393ci LT1 with a 250hp shot-o-nos(down for the count)
Working on my "Beltless Boost" project
It's a very conservative engine dyno. The guy took an engine from another shop that dynoed at 630chp and made 525chp on his. I was told it's closer to rwhp than chp. But the real test is when we get it to the track.
It was also raining when we did it so I'm sure the air wasn't perfect. But its a good start.
I think INTMD8 did some camshaft testing and found that a reverse split made about the same power as a regular split duration cam. He made the most power with a single pattern, and several other turbo cars have had very impressive results from the same.
My understanding talking to Jose and some of the Turbo Buick crowd, is that a reverse split should be used when backpressure is really high (3x boost), a normal split if backpressure is really low (at or near boost), and a single pattern anywhere in the middle.
Mike
Mike
Well we decided to turn up the boost last night. It was really weird. The boost would go to 12 or so at peak torque and then start dropping off back down to 10 or so at max rpm.
Am I running out of compressor? Or are the back pressures getting too high once I start moving the air that it won't spin the turbo fast enough?
We did get it up to 14.5psi and the boost still dropped back down to 11 or so, but on that run we popped a head gasket! So much for cometics being the end all in head gaskets. My mechanic thinks that there was too much cylender pressure from the small exhaust lobe and the high boost it couldn't take it.
Any comments from the peanut gallery as to what's going on here??
Originally Posted by RealQuick
What cam did you use before?
When I was messing around with the turbo stuff before I had a 230/236 on a 113. I thought that was going to be too big for my 383 with stock manifolds on it. That cam has 7 degrees of valve overlap in it
What power did you make with it? Who spec'd your current baby cam?
1.) 230/227 .544/.560 lift 114 LSA
2.) 232/232 .539/.539 lift 114 LSA
3.) 224/218 .536/.528 lift 114 LSA
4.) 221/217 .540/.539 lift 115 LSA Cam Motion
Here's the link to the old post
http://web.camaross.com/forums/showthread.php?t=333673
i would think for a good DD cam on a 383 you'd look more for something like 230/228 .580/.580 116,because the reverse split will help stop any reversion since you have stock manifolds like i do.
