Boost Pulley Sizes
Old Jun 10, 2003 | 12:21 AM
madlasher's Avatar
Boost Pulley Sizes
I have a P600b procharger that is supposed to be pulleyed for 15 lbs of boost.
My question is does anyone know the diameter of the crankshaft & the blower pulley?My crank pulley is approximatly7 3/4 inches and my blower pulley is 2 1/2 diameter.
Any help would be apreciated.
later...Keith
Old Jun 10, 2003 | 06:53 AM
IDOXLR8's Avatar
I would recommend against running the 15lb pulley on your P600B. I wouldn't recommend going anything more than the 12lb pulley.
Old Jun 11, 2003 | 09:50 PM
madlasher's Avatar
Where can I get a 12 lb pulley and how much?Mine are 12 rib pulleys.
later...Keith
Old Jun 12, 2003 | 07:32 AM
95 Silver TA's Avatar
You can get them from www.westol.com/lpavtis
He offers great prices and his customer service is unmatched.
Hope that helps,
Claude
Old Jun 12, 2003 | 01:06 PM
Mr. Z28 73/97's Avatar
If I'm not mistaken the P600 & P1200 series blowers have a 7.66" crank pulley and depending on what boost level 3.05" or 2.95" or 2.75" blower pulley. They also have a 3.05-1 stepup ratio.
Old Jun 12, 2003 | 06:29 PM
madlasher's Avatar
Are those Blower pulley diameters 3.05,2.95,2.75?
also exactly what is 3.05 step up ratio?
later...Keith
Old Jun 16, 2003 | 08:12 AM
Yes 3.05, 2.95 & 2.75 are the blower pulleys, the step up ratio is similar to you rear gear ratio like a 3.73 will pull harder than a 3.08. What the step up ratio does is allow you to figure out the max rpm you can run your motor before you reach the redline of the blower itself. For example my P1200 has a max blower speed of 60,000 rpm, well what engine speed does this equate to, take the crank pulley diameter divided by the blower pulley diameter multiply that by the step up ratio then multiply that by your max engine rpm to get blower speed at max engine rpm.
Example: 7.66/2.95=2.5966 x 3.05=7.92 x 7300 rpm = 57813 rpm
Hope this helps explain the step up ratio.
Old Jun 17, 2003 | 09:27 PM
TravisA's Avatar
later...Keith
Didn't i teach you anything Keith j/k
You wanna sell me your 12 rib setup
later
Travis
Old Jun 17, 2003 | 09:38 PM
madlasher's Avatar
No not just yet,but Iam looking for a cooler for it
later...Keith
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
drptop70ss
Mar 26, 2015 01:50 AM
