boost gauge
Old Dec 3, 2003 | 06:37 PM
nigsrig's Avatar
boost gauge
i am ready to order a boost gauge and i see that they have two available--105-6159 Boost, 30-psi Boost/30-In.Hg.(Vacuum) |--or this one 105-6160 Boost 0-30psi | View Product one deals with vacuum ..i'm not sure which one to get..by the way i have a supercharger and want to know how much boost i have
94 lt1 camaro procharger
Old Dec 3, 2003 | 07:21 PM
drewstealth's Avatar
Did you just buy the car or something? You should know how much boost you are running on the car. It is very important to know. Also there is a Forced Induction section on this site. They can help you out a lot more about your questions regarding that kind of stuff then we can.
Old Dec 3, 2003 | 07:22 PM
95 Silver TA's Avatar
You would be better off asking this question in the Forced Induction section. But If you are running around 20 psi or less of boost then I would recommed getting a gauge that has Max boost of 20 psi. It would be much easier to read.
I am running about 10-11 psi of boost and I am running a guage that reads 20psi max. Since its a 280* sweep guage its easier to read when I am under boost. A guage that reads upto 30 will be alot harder to read since the number will be smaller. Here is a pic of my gauge, its located in the AC vents of my TA along with my Electric FP guage. Both are 2 5/8 Sportman Comp guages from autometer. I dont have the part number any more but you can call up Autometer and they can recomend a good one for your needs.
http://images.cardomain.com/member_i...29_11_full.jpg
Hope that helps,
Claude
Old Dec 3, 2003 | 08:28 PM
nigsrig's Avatar
so whats the difference in the two gauges i have listed above..i know they are both for boost but one says vacuum..will they both work or is one different than another?
Old Dec 3, 2003 | 09:04 PM
97WS6SCharged's Avatar
The one that goes from 30 inches to 30 PSI will point to the left of zero when the car isn't getting any boost from the supercharger. The one that reads from 0-30 PSI will sit on zero until you begin building boost. I went with the Phantom series that reads from 30 inches of vacuum to 20 PSI of boost.
Here's a link.
http://store.summitracing.com/partde...art=ATM%2D5701
Here's one for the 0-30 gauge.
http://store.summitracing.com/partde...art=ATM%2D5704
Old Dec 3, 2003 | 09:23 PM
Brent94Z's Avatar
Super Moderator
I'll move this to the Forced Induction forum...
Old Dec 4, 2003 | 04:41 AM
nigsrig's Avatar
thanks for the help guys.i understand now
Old Dec 4, 2003 | 10:20 AM
Roadie's Avatar
I would recommend a 0-15 or 0-20 psi boost + vaccum gauge.The lower boost reading is nice because you can read the numbers better. The vacuum is good in the event that you swap cams out in the future, it'd be nice to see what kind of vacuum you are pulling to see if it's enough for power brakes, etc.
Old Dec 5, 2003 | 12:44 AM
96 WS6's Avatar
The vacumn/boost one is the one you want.
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
themex2002
Sep 2, 2015 03:47 PM
Aug 7, 2015 01:26 PM
Henson071
Aug 4, 2015 09:32 AM
