boost gauge
Lots of places. If you hook it up before the intercoolers it will give you the boost reading from tha actual supercharger. If you hook it up somewhere on the intake it will give the boost reading that the motor will see. I would tap the vacuum line for the FPR that should give you a good reading. This might not be the best place but it will work and it will tell you what the motor see as far a boost.
Michael
Michael
To get an accurate reading of your intake manifold pressure, tap directly off the intake manifold (the two ports above the PCV stated above is a good place). Teeing in further away from the manifold may give you an inaccurate reading.
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
[Interior] Interior protection
themex2002
Sep 2, 2015 03:47 PM
Aug 7, 2015 01:26 PM
Henson071
Aug 4, 2015 09:32 AM
