Boost controller?
Old Feb 17, 2009 | 02:32 PM
1996camaroSSclone's Avatar
Boost controller?
Would I be better off to run a boost controller if the car is strictly drag? If so what are some good ones to choose from?
Old Feb 17, 2009 | 03:50 PM
reamo04's Avatar
if its strictly drag, just throw in a higher PSI wastegate spring
Old Feb 18, 2009 | 09:10 AM
mn_vette's Avatar
If this if for draging I would look into the EBOOST2 controller. Its an electronic boost controller and it has alot of nice features. Things like selecting a boost level based on rpm, gear selection, or time. It also helps keep the wastegate closed instead of just keeping the boost reference from getting to the gate.
Also having an electronic boost controller will help with quick and easy adjustments if you end up getting to a track that isn't properly prepped.
http://www.turbosmartonline.com/index.php?id=42
Download and read through the manual.
Old Feb 18, 2009 | 10:19 AM
jsetzer's Avatar
Either of the above ideas are good. I have the cheapo ebay $5 one and its kind of crappy. I can run more boost than my spring is rated for, but its never reliable, I see different boost levels fairly regularly.
Old Feb 18, 2009 | 02:02 PM
I'll have to look into it. Thanks for the help.
Old Feb 19, 2009 | 07:22 AM
1982z28with18s's Avatar
Joe P makes a really good manual boost controller, google it.
RUENUF
Mar 13, 2016 03:37 PM
Formula Steve
Sep 19, 2015 08:48 PM
Henson071
Sep 18, 2015 04:01 PM
Aug 7, 2015 01:26 PM
Henson071
Aug 4, 2015 09:32 AM
