Blown head gasket?
Old Jun 24, 2004 | 10:45 PM
BAD 97 WS-6's Avatar
Blown head gasket?
The oil is fine.
But I get white smoke only at idle, but it stops.
The first time was about 2 weeks ago. I pulled over, but as I drove to pull over, it stopped. Did not do it again until tonight. Once again it stopped. If it was a blown gasket, wouldnt it smoke all the time?
Old Jun 24, 2004 | 10:48 PM
97WS6SCharged's Avatar
Could be a leaky head gasket. It'll probably blow the first time you get on it really hard.
Old Jun 25, 2004 | 06:04 AM
IDOXLR8's Avatar
Re: Blown head gasket?
Originally posted by BAD 97 WS-6
The oil is fine.
Your best bet would be to do a leakdown test.
Old Jun 25, 2004 | 06:48 AM
Whats a leakdown test?
Weird, I drove the car to work today. Drove it pretty hard. Took it up to 8 lbs boost a couple times.....and nothing.
Old Jun 25, 2004 | 07:07 AM
IDOXLR8's Avatar
No offense but I would not recommend driving the car hard until you find out what is wrong with it.
It basically will measure the amount of blow bye. You are basically pressurizing each cylinder with a known pressure and measuring the amount of air that is leaking. This could be due to bad rings, valves not seating properly and popped head gasket.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
