Blowby? / possible blown intake gasket
Old May 10, 2009 | 08:21 PM
  #61
tritonium's Avatar
I give up...
Rebuilding to non SC
If anyone is interested in a new vortech supercharger and mounting kit ......
https://www.camaroz28.com/forums/sho...ferrerid=54351
Old May 10, 2009 | 10:50 PM
  #62
roguedriver's Avatar
Just for the record brad, it wasn't the metal from the charger that put the hole in your piston generating blow by. That was most likely the tune being off for the boost you were putting to it. A hole in the piston (i'm assuming your talking a melted hole) is caused by a lean out due to lack of fuel, which can also cause detonation and crack pistons. The damage the metal going through there would most likely cause would be tearing up your bearings once it gets in the oil, maybe the valve seats, cylinder wall scoring if it gets that far, etc. There are many that run boost safely and reliably once the tune is dialed in. So don't get discouraged incase you change your mind and put it back on there. You just need to build and tune for it, thats all.
Ken R.
Old May 11, 2009 | 04:50 PM
  #63
tritonium's Avatar
Ken R.
Thanks Ken
Old May 11, 2009 | 05:38 PM
  #64
tritonium's Avatar
Originally Posted by tritonium
Thanks Ken
We don't know how to tune it - we bought a chip burner/emulator from moates - but we do not have the knowledge to tune the car or burn a chip for it. It makes us uncomfortable.
Is there anyone that is running boost on a 93 that has a tune that would work for my car? The knowledge part is what we are missing in this category - also would i need to buy a new spark retard system like the crane fireball + module?
Old May 12, 2009 | 06:44 PM
  #65
tritonium's Avatar
Is it possible to get an Air/Fuel ratio reading using an ALDL cable with tunerPro? on a 93 camaro?
Old May 12, 2009 | 08:36 PM
  #66
Kevin Blown 95 TA's Avatar
No, you need a wideband o2 sensor and some kind of gauge or logging capability to do that
Old May 12, 2009 | 08:43 PM
  #67
tritonium's Avatar
thanks for all your help everyone - going back to NA
RUENUF
Mar 13, 2016 03:39 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
dfarr67
Apr 10, 2015 07:44 PM
Jazsun
Dec 29, 2014 12:14 PM
