Best company for custom pistons?
I need to order a set of custom dish pistons for my turbo 421 small block and was wondering who you all recomend. I was thing of JE, SRP or Ross. But who would you choose and why? BTW, the pistons I need to order will have a 34cc dish to acomplish a compression ratio of 8.5 to 1 with 72 cc chambers in the heads.
The current pistons in my car are JE's as there was an off the shelf that worked, but previously I ordered a set of custom pistons for a 408" motor for my dad's dakota from CP pistons. I can say I was impressed with the way they worked with me in getting the pistons spec'd out and the quality seems to be outstanding.
You could do it with a 5.850" rod, but not a 6". There's not enough material above the pin to allow that much dish. The 4.155 bore helps, since the dish won't need to be as deep as a 4.030 bore would require to acheive the 34cc's you're after.
Thats quite the dish, I have always got my pistons from ross. I think you will be better off with a 5.85 rod. I think even with these rods you will have to run a rail support on the oil ring. call up ross and ask for George. He can give you all the info you need to complete your project.
I just talked to my head porter and he said he could probably open up the chambers on my heads to 78cc. That would leave me needing a 28cc dish. That sounds a lot more doable than 34cc. Remember, this if for a compression ratio of 8.5 to 1. I guess if I have to I could always run a bit higher.
Originally posted by 383 LT4
Oah, I forgot to ask, If my crank is for a 6.00" rod then can I use a 5.850" rod? Will I need to profile the crank more so it will have enough clearance?
