ATI LT1 install rerouting oil cooler hose
Old Feb 17, 2004 | 08:31 PM
Metlegleo's Avatar
On the intall of a P1SC on an LT1, ATI advises to turn the waterpump fitting for the factory oil cooler from the 4 o'clock position and move it to the 10 o'clock position and to cut the hard line just behind the crank pulley. From what I understand they then advise to run a really long new hose routed towards the passenger side of the car . Has anyone came up with a better solution?
Old Feb 17, 2004 | 11:04 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
My suggestion would be to remove the factory oil cooler.
Old Feb 17, 2004 | 11:31 PM
sleeperz28's Avatar
I second that it costed me a motor
Old Feb 18, 2004 | 02:09 AM
Sparkz28's Avatar
what do you take out....?
Old Feb 18, 2004 | 09:09 AM
sleeperz28's Avatar
You take a rubber hose go from pump to rad. Than the sandwich between the oil filter and block is removed. I put an aftermarket cooler in because I need one. Unless you have a turbo your oil temps should not get that high. After my cooler install I noticed a 70 degree drop in the oil temp. As you can see it worked out very well, but was very expensive.
Old Feb 18, 2004 | 08:30 PM
INTMD8's Avatar
Whose oil cooler setup did you go with, and where did you get it from?
Is it a sandwich type like stock, or does it relocate the oil filter?
Old Feb 19, 2004 | 12:48 PM
sleeperz28's Avatar
The cooler I got from a local speed shop. Its an Earl 50 row cooler however, they no longer make this cooler. It was too big so they didnt sell very well, the next size down is the 40 row.These coolers are designed for the older porsche that were oil cooled only. They go for around $500, but I got a hell of a deal. Actually the shop I bought mine from may still have one left in stock. They are more of a big block with nitrous shop, so this is not a hot item.
The way its setup is a sandwich. This only routes the oil out and back into the motor so no restictions like the factory. I run -10 line in and out of the cooler. You can see it mounted in the front of my car in one of the picts if you look closly.
If your interested I can get you their phone number
HectorM52
Jul 30, 2017 11:46 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
