Anyone running a XE 224/236 cam in CA?
Old Apr 14, 2005 | 10:08 PM
EDS Z28's Avatar
Hey guys,
I'm pulling out my gm hotcam due to a vented opti conversion.
I figured to upgrade the camshaft and other valvetrain parts while the motor is apart, again My motor is a blown 355.
I was looking at the CC XE blower grinds, 218/230 and the 224/236 duration at 114 lsa cams. Does anyone know if these are capable of passing smog. I did pass the last test easily with the hotcam. The 218 one looks like it has no overlap, while the 224 has 2 degrees of overlap, which isn't all that bad.
Does anyone know how much overlap the hotcam has? I don't even know.
I liked the sound of the 224/230 from a video on LT1 tech, it sounded awesome.
Looking to add some beehive springs along with the cam.
Old Apr 15, 2005 | 11:16 AM
OBE1 95Z28's Avatar
Re: Anyone running a XE 224/236 cam in CA?
I'm running the 218/230/114LS cam in my blown 350 95 Z28 and my friend runs the 224/236/114LS cam in his blown 383 95 Z28 with AFR heads. Both cars here in San Diego passed smog.
Old Apr 15, 2005 | 11:27 AM
EDS Z28's Avatar
OBE1,
Hey man thanks for that info. That's good news. How is the idle on your cam, is it lopey and how much vacuum? With the hotcam I had around 15" manifold vacuum at 900 rpm.
I'm leaning towards going with the bigger cam since my car is not a daily driver.
Old Apr 15, 2005 | 09:33 PM
D James's Avatar
well my 224/236 doesn't lope very hard, actually its very slight, unless you open a cutut, then it gets ok. Drivability is great, I never tuned mine so there was some slight cam surge at 5-10 mph, but thats it, all other manners were great, I don't know how much vacuum it had, but I couldn't tell a difference in braking and it idled fine
Old Apr 15, 2005 | 09:44 PM
EDS Z28's Avatar
Thanks for the info James. I had a little cam surge too with the hotcam. It's no big deal to me.
Looks like I'm goin the 224/236 route. Now, I need the other valvetrain parts to go with it. According to comp cams catalog, the springs to get are the 986's. I was going to go with the beehives, but have read some negative comments about them from Crane.
Old Apr 15, 2005 | 09:53 PM
97WS6SCharged's Avatar
I'm running Combination's EX612 springs with mine.
Old Apr 15, 2005 | 09:56 PM
OBE1 95Z28's Avatar
I pull 17" of vacuum at 900 rpm with the 218/230. I had pretty bad cam surge until I hooked up with a great tuner - Jeff Creech. Only a slight lope with this cam.
Old Apr 15, 2005 | 10:20 PM
EDS Z28's Avatar
Wow, 17" is pretty damn impressive. I wonder what Jeff did to smooth it out? I know it's all a secret though
I know adding fuel to the motor at lower rpm's helps the idle a lot. The problem is this may burn out your cats, which are designed to run around stochiometric 14.7:1 most of the time.
How can I get ahold of Jeff?
Old Apr 17, 2005 | 07:28 PM
OBE1 95Z28's Avatar
Jeff owns Carolina Auto Masters, a tuning shop in North Carolina. A local guy, SS MPSTR, has organized 2 group dyno sessions which makes it worth Jeff time to fly out to Southern California for a 3 - 4 day tuning session. Plans are to have Jeff back out by June. See the thread below for details of the last session:
http://web.camaross.com/forum
s/showthread.php?t=351603&highlight=Jeff+Creech
Private post SS MPSTR to get on the list for the next tuning session.
Old Apr 19, 2005 | 07:45 PM
limige's Avatar
Hey, check your pm.
mike
Old Apr 23, 2005 | 08:50 AM
c0rey's Avatar
I just ordered the XE 224/236. I ordered the whole valvetrain. I cant wait to get it in and see how it sounds. Does it sound simalar to a hotcam?
Old Apr 25, 2005 | 02:33 PM
sherwinZ28's Avatar
I passed my 230/236 112 LSA heads cam 96 OB2 Z-28 at a test only center here in cali. The car is stock bottom end untuned...waiting for tunercat. No tricks were used as far as i know.
Amshnock
14
Jan 18, 2015 11:47 AM
1775.Z28
Jan 11, 2015 10:51 AM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
