another update
Old Jan 31, 2003 | 09:13 AM
  #16
96speed's Avatar
Originally posted by Abdullah
Jordon. thanks for the reply. i have a question, do you think the GTP stage 2 AFR 220cc LT4 heads that i'm doing now by Craig are too big for a YS-trim supercharged 396 LT1? do you think going with a 383 is better?
because i saw you are doing 190cc AFR heads for your turbo 383 and they are even smaller than the 210cc AFR heads you did for your NA 401 LT1?
Not sure how easy it would be, but I would send the heads to another shop to have checked out before they get assembled. If they are confident about it there should be ZERO problems from them (GTP). I say this because I am not sure they is a flow bench in Kuwait. I have never heard of GTP heads flowing as advertised from GTP, and recently experienced it first hand - no hearsay! Buyer beware.
Good luck,
Ryan
Old Jan 31, 2003 | 01:42 PM
  #17
89ProchargedROC's Avatar
Abdullah...jordans heads started out as 190cc but after his porting are probably in the 200-205 range
Old Jan 31, 2003 | 06:53 PM
  #18
JordonMusser's Avatar
West South Central Moderator / Special Guest
as procharged said, They will end up around 205-210cc when done.
The only reason I am started with 190s is "the price was right". I would prefer 195s.
i think the GTP 220s will work great, craig knows how to make stuff go fast.
Old Jan 31, 2003 | 07:18 PM
  #19
Abdullah's Avatar
Jordon, one more question, why you went with a 383 over a 396? thanks.
Old Jan 31, 2003 | 08:17 PM
  #20
I felt that I couldn't get enough piston on top of a 396. Also, no need for cubic inches.. cept at low(non boost) rpm. The turbo will more than make up for it
Old Feb 7, 2003 | 12:06 PM
  #21
new pics.
http://www.fastblackcar.com/camaro/turbomotor/
BOV pics, and some head pictures. if I can find a ride around town today to get some bolts, I will hopefully have the motor in tonight!
Old Feb 8, 2003 | 09:04 PM
  #22
CW_BUFF's Avatar
I like you fan set up for painting in the garage, that is a good idea. I had never thought of that I used to just leave the garage open so it would vent out. Your car is so bad, I wish I still had mine.
Old Feb 22, 2003 | 03:08 AM
  #23
OK, more pics! about 90% done with ABS relocate, just gotta bend one more line(see pics).
Also, there is a pic of where the turbo is gonna be mounted.
looking to have all the turbo plumbing done next weekend.
Old Feb 22, 2003 | 03:21 AM
  #24
Jim S. '95 Z28's Avatar
Lookin' good.
BTW, what type of flaring tool are you using for the brake lines?
Old Feb 22, 2003 | 12:32 PM
  #25
I rented it from AutoZone.
Old Feb 22, 2003 | 02:00 PM
  #26
Coo. Good to know that Autozone tool works on mild steel.
Old Feb 22, 2003 | 04:27 PM
  #27
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Looks very nice!
My setup will be very similar to yours. My biggest worry is going to be drivers side plug access.
What size primarys and crossover pipe did you decide to use?
I'm going to run 1 5/8 primarys, and a 2 1/4 crossover tube.
Old Feb 22, 2003 | 08:10 PM
  #28
I am using 1 3/4 primaries and 2.5" cross over. it has plenty of room for plug access....
Old Feb 28, 2003 | 02:35 PM
  #29
http://www.fastblackcar.com/camaro/t...rborouting.jpg
little tidbit of whats going on
Old Feb 28, 2003 | 04:46 PM
  #30
Mikey 97Z M6's Avatar
Jordan,
Looks good. Mine's gonna be a up a lilttle bit from that location, but still very similar. I haven't decided if I'm gonna have my turbo oriented like yours, or turned 180* with the intake coming from the closest fender. How much extra clearance did that BMR K-member give you for the downpipe, and is it 3" or 3-1/2"?
Did you use the same basic x-over design (minus the lame wastgate location) as the turbotech kit?
Mike
