Another minor setback
Old Feb 21, 2007 | 04:05 AM
breakmyfootoff's Avatar
Just got my new exhaust welded in today and went out for a test run, ended up loosing the blower belt which took out the cooling fans (literally broke the fan loose from the plastic fan shroud), wiring for the temp sending unit, wiring for the electric water pump, and the oil feed line for the blower . I'm gonna order a new oil feed line in stainless steel after this little adventure.
Old Feb 21, 2007 | 09:01 AM
96TurboWS6's Avatar
off topic..but what headgaskets and heads do you use to get down to 8.3:1 with those pistons? I have trickflow 62cc heads and felpro 1074s and with a stock deck height it came out to 8.3:1
Old Feb 21, 2007 | 09:21 AM
CALL911's Avatar
That sucks man! Which blower were you running? My D1SC's belt gets close to the fans casing. I always was concerned that the two might make contact and take out the belt.
Good luck with the fix.
Old Feb 21, 2007 | 12:26 PM
xxsaint69x's Avatar
probably runing cometics..you can get any thickness you want
Old Feb 21, 2007 | 04:08 PM
Lisa33's Avatar
**** happends, first leagle event 2005 i broke a blower belt around the 60fot line , destroyded the "plastic part" on the heater hose and also smashed the tempsender on the waterpump, it run like crap the 60miles home (replaced the broken heather hose) just lucky i didnt smashed the cables to the waterpump
Old Feb 21, 2007 | 07:27 PM
Kevin Blown 95 TA's Avatar
Lisa I am amazed you drive your car to the track!
Old Feb 21, 2007 | 09:14 PM
I'm running the iron LT1 heads which also have a 62cc combustion chamber and the 1074's also. Looks like I'm gonna get out pretty cheap on this one, I have some friends at a hydraulics shop that are gonna make a stainless steel braided oil line for me and another friend had a fan assembly laying in the garage so it's only gonna cost me 16.00 for a new pigtail for the temp sending unit .
Old Feb 21, 2007 | 09:28 PM
I'm running the T-Trim, it had an inch of clearance or more before the belt came loose and knocked it off the housing
Old Feb 22, 2007 | 01:43 AM
Lisa33's Avatar
Did it for 2 1/2 year but not any moore, bought my a trailer a year ago
2QUIK6
Sep 17, 2016 02:31 PM
karpetcm
Dec 16, 2015 09:07 PM
football4life
Oct 4, 2015 07:48 AM
tommalcolm
Sep 11, 2015 03:39 PM
mlopezart
Sep 8, 2015 12:15 PM
