58 mm TB needed with boost?
Old Jul 25, 2004 | 11:39 AM
  #31
tjwong's Avatar
Re: 58 mm TB needed with boost?
Originally Posted by INTMD8
I tested pressure drop through my entire induction system when I had the single turbo.
From the outlet of the turbo, to the intake manifold, there was a .5 psi pressure drop. This is through the induction tubing/intercooler/58mm tb.
I was going to try a monoblade, but I've heard that the blades can bend when lifting off the throttle.
May I ask what means did you use to test pressure drop in your induction system? IE; did you use a DP meter across two points or just used a pressure guage at different points and were the test conditions the same?
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
