? on a 383bottom end we just put together
Old May 5, 2003 | 02:13 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
Car is running fine right now. The motor is 9.1 compression,cc306 cam, and stock unported heads, with better springs in it. Has a Paxton on it. My question is, how should this car perform being the heads are untouched. It was making 10 pounds of boost before, but only 6 pounds now. Also, he is not running a MSD, and when I laid into it today, it was cutting out. He said it would do that before, I'm thinking it's due to not having a MSD. It has the paxton super fueler on it, plus 30lbs injectors. I'm just not sure how this thing should run, because I never drove it before the motor was done. Thanks for any input.
Neal
Old May 5, 2003 | 06:31 PM
PNYKILR's Avatar
I forgot to mention that, as soon as it hits around 5,000rpm's it just doesn't want to go past that. It goes through the rpm band fine untill 5k then takes alittle bit to get to 6k. It also starts to loose boost. I'm not sure if it's the belt slipping or it's the fact that when you go past 5k the motor is hesitating.
Old May 7, 2003 | 07:14 PM
PNYKILR's Avatar
ttt
Any one????
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Hurin
Dec 13, 2014 07:38 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
