383 and P600B procharger?
Old Jan 10, 2005 | 06:48 PM
BMAN'S SCZ's Avatar
Hey guys, I am thinking of going this route but is my head unit to small to run 12# on a stroker motor? I think I will be close to exceeding it limits. 15# is out of the question huh. I don't want to upgrade to a D1 just yet. Also is there pistons available in the -30cc range with a 6" rod for the stock 58cc heads? I was looking on cmc website and they had just 5.7" rods with that dish. I would like to keep the c.r. around 9.0-1. Please let me know what everyones thoughts are on this. Thanks.....John
Old Jan 10, 2005 | 07:39 PM
Lonnie Pavtis's Avatar
Re: 383 and P600B procharger?
A P600B with decent heads/cam will only make around 10# with the smallest 15# pulley. The D-1 will make around 18#.
Not sure about a 30cc dish w/ a 6" rod. There may be rod to piston interference.
You could rework the heads to 65cc chambers & run a 16cc dish for approx. 9.2:1. This will get you close.
Hope this helps.
Old Jan 10, 2005 | 07:43 PM
BMAN'S SCZ's Avatar
Thanks Lonnie, but will I be over turning the blower with a 15# pulley? Would the p600b still be effecient with that setup or just create to much heat? Thanks again for the advice...John
Old Jan 10, 2005 | 11:25 PM
93turbo5oh's Avatar
ive turned vortech s-trims well past their absolute max (and waaaayyyy over max effiecient) without an intercooler and the power continued to climb. you have an intercooler, dont worry about it.
Old Jan 11, 2005 | 05:52 AM
IDOXLR8's Avatar
I would highly recommend against overspinning the P600b. If you do good luck on the blower rebuild and motor rebuild. I had a 15lb pulley on my p600b and from experience can tell you it is very inefficient for a setup like yours. Your best bet would be to save up and go with a D1SC.
Old Jan 11, 2005 | 09:06 AM
94 NO TOP Z's Avatar
With the 12psi pulley on my 355 I only saw about 10-11psi... so with a 383 it would be even less. The 15psi will over rev the P600 if you get into the 6500rpm range. I wouldn't go any smaller than than D1 if I were you.
Old Jan 11, 2005 | 03:39 PM
tryintogofast's Avatar
Yes JE makes a -31 cc dish piston for the 5.7 rod but they also make a -28 cc dish piston made for a 3.75 stroke and 6.0 rod. My setup is going to be about the same as yours by the looks of things. Except I'll be running a s-trim with water injection at about 10#'s. I think the part number of the piston is 170817 and with a 58cc head you'll have 9.2 to 1 compression.
Mikey
Old Jan 11, 2005 | 05:43 PM
BMAN'S SCZ's Avatar
Thanks for all the info guys, I'll keep reading up, and save my money for a D1. Does anybody off hand know what the price would if I exchange my p600b for a D1 unit? Thanks again....John
Old Jan 11, 2005 | 06:20 PM
The P600B is good to 6600rpm w/ the 15# pulley.
There is no trade in for the P-600B to the D-1.
Old Jan 11, 2005 | 06:50 PM
BMAN'S SCZ's Avatar
Thanks Lonnie. I was just looking in my procharger book to find the formula. What size is the 15# pulley? About how much is a brand new 8 rib pulley?
Old Jan 11, 2005 | 10:25 PM
It is a 2.55", but you can forget about using an 8rib. The small dia will even slip w/ a 12 rib setup. Not enough belt surface area on the small dia pulley for traction.
Old Jan 13, 2005 | 10:40 AM
guardrail's Avatar
I'm actually running a 383 with a P600B, and like they all say, it only pulls around 10#, I haven't had any over revving problems, but i'm usually pretty careful about stuff like that. The p600 is plenty for me, the car is a daily driver and occasional strip car, however you will probably be happier with the D1, but I doubt you'll be disappointed with the p600.
Old Jan 13, 2005 | 05:59 PM
The D-1 is much better suited to the 383. Actually it is better at achieving max boost than a D-1SC due to the 4.44 internal step up ratio.
The same motor achieving 10# @ 6500rpm w/ a P-600B will make about 18 w/ a D-1. The D-1SC will be close, but the minimum pulley size limits the max boost ratio for lower RPM usage (under 6k).
Old Jan 22, 2005 | 02:31 PM
mzgp5x's Avatar
I have a 383 with a 6" rod. I had a 12 psi pulley p600b on it. The belt contact was very short even with a 12 rib. I rolled the small key on the driven side. Lucky I found it. The p600b has a very small key and (I think) a 5/8 shaft. The D1 has a dual key and a 3/4 or 1" dia. shaft. I like the D1 much better with the 4.44:1 stepup. I'm runing a 12psi pulley now, and, I have a 15psi pulley I've been thinkin of. I think 15 psi is to much for my 9.5:1 comp. ratio.
Old Jan 22, 2005 | 02:40 PM
BMAN'S SCZ's Avatar
mzgp5x Thanks for your reply. What kind of numbers where you making out of your P600B? What did you see on your boost gauge? What heads and cam? Thanks.......John
