Are 3 set screws enough to hold balancer hub on crank?
Old Apr 11, 2005 | 10:02 PM
hellostop's Avatar
I have a newly installed D1sc on a 94lt1. The tuner suggested I have the hub drilled, tapped, and three set screws installed to pin hub to crank - crank also notched with drill bit to engage set srews.
Will this hold as well as a hub machined for a key?
Old Apr 11, 2005 | 10:41 PM
Bryan 94 Z28's Avatar
Re: Are 3 set screws enough to hold balancer hub on crank?
Damn, that's a good idea. I'd never even thought of doing something like that, but it'd probably be easier overall than notching the hub.
As long as you make some sort of indentation on the crank snout for the set screws to snug in to, it'd be pretty solid. Probably not as solid as keying the hub with 2 slots for two woodruff keys.
Old Apr 12, 2005 | 08:13 PM
lethal93ta's Avatar
I just keyed my hub on mine, I know that thats not going anywhere, id be worried that the screws would back out on you from vibrations if they back out and spin on the crank that would be a pain to fix.
Old Apr 12, 2005 | 10:12 PM
engineermike's Avatar
How is that easier than keying the hub?
Old Apr 14, 2005 | 07:14 PM
hellostop's Avatar
Its easy as I drilled my own holes, and used helicoil inserts for threads. I dont have a verticle mill to cut a keyway in the hub, or whatever machine that takes.
Old Apr 14, 2005 | 07:34 PM
Why did you use helicoil inserts? Why not just tap the holes?
Old Apr 14, 2005 | 09:59 PM
hellostop's Avatar
Theres only enough room for 4-5 threads, and I wanted good full depth strong threads. Cast iron is hard to tap and i've had better luck with the coils. kiss principle
Old Apr 14, 2005 | 10:06 PM
breakmyfootoff's Avatar
Could this cuase any strengh issues with the hub?
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
