Is a 1.05 ex A/R ok for my setup??
Old May 12, 2005 | 09:28 AM
menlatin's Avatar
I found a t70 turbo, but it has a 1.05 ex A/R. I'm not sure its big enough for my 355. I'm shooting for 650-700 fly hp at what ever neessary pressure. Here's my motor
sbc 355
Ported GM 441's (285/237 @ .600, 2.05/1.60)
Comp 274nx cam (274/292, 230/244) hyd flat tap
10.5:1 comp (Using meth/water inj.)
all forged bottem end (supposed to be good to 800hp/8,000rpm)
Currently making ~430 hp n/a, but has never been properly tuned, so maybe 460 when tuned.
I tried the rayhall turbo calculator and it suggested 1.22 A/R, but i thought i'd seen some smaller ones used on some f-bodies and such.
Old May 12, 2005 | 03:25 PM
JZ 97 SS 1500's Avatar
Re: Is a 1.05 ex A/R ok for my setup??
It its a front mounted system then yes you can run a 1.22, but it also depends on the turbine wheel in the unit. If its a rear mount, forget it, stick to a small .81 or so.
Jose
Old May 13, 2005 | 02:43 PM
menlatin's Avatar
well i'm not quite sure. This is going into my 72 truck, which has 4.11's and 700r4 so i'd rather have something that spools up at about 3000rpm so i can maintain somekind of traction off the line. I also can't run much more than a 10.5" slick, maybe 28" max heigth. My plan was to is to use some hooker pro comp headers into a Y, and then run that back up the engine bay to the turbo (next to the passanger side header). I know it sounds like a lot of piping, but i have enough room. I guess with all the distance til the turbo i should go with the .84 A/R since that right there is going to provide some lag.
Old May 13, 2005 | 07:47 PM
engineermike's Avatar
I would concentrate more on shortening the piping and get the larger A/R. Use some shorty headers flipped or something.
Old May 13, 2005 | 09:00 PM
menlatin's Avatar
Hm. ok, so a 1.5 primary should ok then.
Also, does my cam seem like too much or is it fine? its a 113 lobe serpation.
Old May 14, 2005 | 01:35 AM
I think 1.5 would be Ok since some are making 1000 hp with 1.625.
The cam isn't too big, but it's not really a turbo cam either.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
