Who installed your headers?
Old Apr 22, 2006 | 10:42 AM
  #31
hulettsz28's Avatar
Re: Who installed your headers?
Did mine myself. If you have the money, pay someone else. I mean, its not really like a huge learning experience so there isnt much of a benefit of doing them yourself, other than not having to spend money. If you are doing LT's and are doing them yourself, make sure you have alot of blocking, a good jack, and another person to help you. One pulling one pushing. Good Luck and dont get squished. Through the top on the driver side, bottom on passenger. And if you do the same as i did on the passenger, you beter have the car up at least 3 feet. That is...if you use long tubes.
Old Apr 23, 2006 | 03:34 PM
  #32
96_pimped_out's Avatar
I installed MIDs once at a friend's on a lift, and once in my garage and I helped on a long-tube install on a lift.
If you're wanting long-tubes, it's my opinion to not even try them in your driveway. HORRIBLE idea. GET SOMEONE WITH A LIFT.
If you're installing mids, it's up to you. It's MUCH easier with a lift, but it's still pretty safe if you decide to do it at home (unlike longtubes)
Old Apr 23, 2006 | 04:08 PM
  #33
96ZCamaro's Avatar
I did mine in a really small garage space with ramps and a jack. Long tubes are a pain. And since my car was in a wreck previously I had to grind on the k member and the steering shaft. What fun all of that was. Put both headers in through the bottom though. Just need to jack the car high for a couple min, get them in. And let it down on the ramps again.
Old Apr 23, 2006 | 06:34 PM
  #34
raxxus's Avatar
I did mine, Longtubes and all. Both went in from the top, but I would leave one engine mount connected while barely raising the engine. The angle let them slide on in after removing a couple things here and there. The biggest pain in the *** was removing my old exhaust so the shop could reinstall it with the headers and ORY.
Old Apr 23, 2006 | 07:08 PM
  #35
matt65's Avatar
I installed my headers.
Old Apr 23, 2006 | 08:48 PM
  #36
sam pace's Avatar
mine took about 4hrs on my brother's lift.
the pacesetters have the best plug clearence by far. also use a good gasket and make sure your flanges are flat you only want to do these once trust me!
Old Apr 3, 2007 | 03:37 PM
  #37
CamaroRacing12's Avatar
so what is the safest way to get the car high enough without a lift? prolly ramps a jack and jackstands and blocks? triple the protection? lol i dont wanna die putting in my longtubes lol
Old Apr 3, 2007 | 03:40 PM
  #38
2000GTP's Avatar
Without a lift, a floorjack and jackstands is about your only option. I don't think the drive up ramps will get the car high enough to get a long tube header in there.
Old Apr 3, 2007 | 07:48 PM
  #39
Rob1997ta's Avatar
headers
I installed mine and it was not a walk in the park. I had a lift also. Use a good gasket trust me I had mine out 4 times.
Old Apr 3, 2007 | 10:06 PM
  #40
Critter's Avatar
me and hosspwr94...both times
Old Apr 3, 2007 | 10:37 PM
  #41
Desutterz28's Avatar
i just did some pacesetter mids on my 94 LT1 and i didnt have any problems. just take out dipstick and go in from bottom on passenger side. tricky to get dipstick back in but i did it without bending it. tighten up spark plugs before u tighten up the headers and it will make it a lot easier. i would recommend percy header gaskets too since they arent supposed to blow out. little extra cost is worth the headache of removing them later. my 2 cents.
Old Apr 4, 2007 | 05:05 AM
  #42
thx 2000! i have been putting this mod off all winter.... its time the sh*t hits the fan!
Old Apr 4, 2007 | 09:21 AM
  #43
gt_biker13's Avatar
I did mine myself using a lift. Try to find a small shop that you can borrow their lift on the weekend, it would really be woth it for a small price. If you cant do that then just make sure you jack up the car safely, with a backup system like concrete blocks or wood.
Old Apr 4, 2007 | 09:49 AM
  #44
2000GTP's Avatar
I'm surprised a shop let you do that with insurance liabilities and all. When I used to work for a dealer, they used to have a fit if we worked on our own cars after hours.
Old Apr 4, 2007 | 10:40 AM
  #45
gt_biker13's Avatar
My dad owns the shop and i also worked there, so i didnt have to actually pay anything.
