Are two cats necessary?
Old Apr 11, 2017 | 07:34 AM
tryme96Z's Avatar
'96 Z28. Hooker LT headers w/ Hooker catback, no cats. Lots of other mods 1.6rr, cc306, port & polished heads, cai intake, throttle body, MSD 6AL...etc.
I have gotten a bit older and cannot stand the smell of the no cat exhaust setup and am looking change that. What are the performance implications of a single high flow cat instead of two? (half the flow! haha) Will it actually be noticeably driving around?
Rear o2s are already programmed out.
Also is https://www.summitracing.com/parts/mpe-94109/overview/ the "CarSound" catalytic converter people commonly refer to on here?
Thanks.
Old Apr 13, 2017 | 08:02 AM
tryme96Z's Avatar
Re: Are two cats necessary?
From what I have found from further research it sounds like two are needed due to proximity to the headers. That being to do a single cat would put it too far back on the exhaust and jeopardize the cats ability to heat up to temp for it it properly do its job.
Now I need to find a cat that is small enough to fit the driver's side with the good old Eibach Proline Springs (~1.5" drop I believe). M6 is hanging out down there too.
Old Apr 18, 2017 | 09:30 PM
Zspoiler's Avatar
It would probably better to put two high flow cats .But you also need to check with emission rules of your state. And whether you have to have a visual inspection as well.
