True duals
Old Apr 13, 2008 | 11:06 AM
scott5's Avatar
True duals
I am getting some pacestter lt headers on as soon as tehy get here and i wanna do a true dual setup whats the best way to do it?
Old Apr 13, 2008 | 04:36 PM
reamo04's Avatar
i would do 2.5" duals
Buy the summit 2.5" universal x-pipe
SUM-642125
Exhaust hangers
SUM-630550
Cone Reducers
FLO-R3025
and some band clamps
WLK-33272
With pace setters, you can basically just weld everything up. I believe the driver side needs to be cut about 2 inches to make everything line up perfect though.
Then weld on your choice of mufflers, and be done with it.
Old Apr 13, 2008 | 10:30 PM
PoloM6's Avatar
and what is the ground clearance with those true duals???
Old Apr 14, 2008 | 12:16 PM
reamo04's Avatar
easily a pop can. Just depends how you weld them, if y ou have them straight or not. Mine had great ground clearance, only time i ever scraped was with 4 people in the car and a trunk load of stuff, and it didnt scrape the exhaust, just the u-bolts i had instead of welding the hangers to the exhaust.
Old Apr 14, 2008 | 11:10 PM
'94 Bad A Z28's Avatar
Here is my 3" true dual setup with PS LT's.
3" Magnaflow True X-Crossover
Couple 3" 45* mandrel bends
Two 3" Dynomax Race Bullets
A few 3" Strap Band Clamps
Old Apr 16, 2008 | 09:05 AM
scott5's Avatar
where is the best place to get a x-pipe
Old Apr 16, 2008 | 09:23 AM
I got mine from Summit.
Old Apr 20, 2008 | 08:32 PM
scott5's Avatar
Originally Posted by Z28Roxy
Do you want dumps or over the axle?
dumps
what all mufflers am i able to use?
Old Apr 20, 2008 | 08:35 PM
scott5's Avatar
do you have a part number? i cant find any x-pipes for my 95
Old Apr 20, 2008 | 11:07 PM
I don't have the part number... and there will not be ANY X-Pipe for your '95 because our cars did not come from the factory with a X-Pipe, so all you will find for our cars are Y-Pipes. You can make any X-Pipe work though.
Old Apr 21, 2008 | 09:10 AM
scott5's Avatar
So what model car should i look for? A vette x-pipe work? or should i just buy the summit one that you cut and fit yourself?
Old Apr 22, 2008 | 12:21 AM
Just buy any X-Pipe in whatever size you want. I just bought my Dynomax 3" True X-Crossover Pipe (X-Pipe), some 45* mandrel bends, some 3" strap band clamps, and two 3" Dynomax Race Bullets. Bada-bing bada-boom, true duals and a X-Pipe.
Old Apr 22, 2008 | 12:23 AM
Don't worry about what model car it fits, just do not buy a full kit specifically for any specific car. If you want to buy a "kit" get a universal kit.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
