pacesetter LTs
Old Apr 4, 2011 | 10:01 PM
Bykerboy869's Avatar
pacesetter LTs
so i put these longtubes in today. well i got them in but still loose bolts because i need to put the plugs and hook the wires back up along with starter and alternator and the the motor mount bolts. got that far in about 2-3 hours. well i noticed that the holes in the flanges on each far end for the bolts to bolt up to the head doesnt line up. but id be damned if my cars a 95z. can anyone chime in on why its doesnt align? i mean every other bolts align except for the 2 outer holes on each header. and how did i do 2-3 hours to get that far along with cussing and throwing tools lol
Old Apr 6, 2011 | 03:10 AM
bobdec's Avatar
Re: pacesetter LTs
My '94 heads have inner and outer exhaust manifold mounting bolt holes at the ends (cyl #'s 1,2,7,8). I believe the pacesetters used the inner holes while the stock manifolds used the outer holes (or reverse) to dark now to go and check.. UPDATED w/edit Pacesetter uses the inner holes...
Old Apr 6, 2011 | 06:10 PM
Re: pacesetter LTs
ok thats what i am using just didnt know if that was right or not. thanks now for getting o2 sensor extensions since i forgot to get them. anyone have a good place to order them from?
Old Apr 24, 2011 | 02:27 PM
6SpdLT1Z's Avatar
Re: pacesetter LTs
Here's JavierZ28's header install walk through. Hookers are slightly different than Pacesetters, but this should give you a general idea.
http://www.zmydust.com/headers/install.htm
GREEN3112
Feb 10, 2019 09:19 PM
FredM
Exhaust System
Feb 8, 2016 02:10 PM
football4life
Oct 4, 2015 07:48 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Slayer
Aug 17, 2015 03:55 PM
