pacesetter lt install
Old Oct 14, 2007 | 11:50 PM
  #16
camarozz95's Avatar
Originally Posted by JoeliusZ28
i didnt have that problem with the sender maybe its an issue on earlier cars? and if the boots are touching you will be ok. i started mine up expecting to burn multiple wires immediately and it never happened, even a year and a half later. when you replace them though you will want to do an over the valve cover routing.
yes I think all pre 95's had the oil pres. sender located up near the oil filter . Later models were located behind the intake manifold.
Old Oct 15, 2007 | 12:41 AM
  #17
Ok4thGen's Avatar
it was up until mid year 1994 that they had the sender on the side of the motor
Old Oct 15, 2007 | 05:30 PM
  #18
Crows89RS's Avatar
i broke my oil pressure sending unit when installing my headers, and I also broke the coolant temp sensor. i had read to be careful of them, but when it came down to it, I totally forgot and broke them both... haven't repaired them yet either... I got the coolant temp sensor in, but when I went to plug in the pigtail, surprise, it was melted from the headers and I got a new oil press unit, multiple times, but it wasn't the right one either time....
Nov 18, 2023 07:21 PM
drptop70ss
May 4, 2015 08:22 PM
WildRidez
Mar 27, 2015 08:22 AM
alex5366
Feb 17, 2015 09:07 AM
