Pacesetter longtubes?
Old Mar 28, 2008 | 06:57 PM
whiteLT1's Avatar
I was going to get me some headers, and was wantin to know if these would be a good choice.
Old Mar 28, 2008 | 07:16 PM
wildweasel's Avatar
The price is right and they get the job done. PROS- excellent ground clearance and price. CONS- Average to poor quality.
Old Mar 28, 2008 | 07:27 PM
whiteLT1's Avatar
I see that you have them... have they been ok for you?
Old Mar 28, 2008 | 07:37 PM
wildweasel's Avatar
Like I said, they get the job done. They've been on 10 months or so, and there's spotty rust on them (yes, they're coated). The flange on the drivers side was bowed 1/4 inch in the middle. There was a lot of weld spatter inside the primaries. But hey, they were cheap, and that was my main focus.
Old Mar 28, 2008 | 07:42 PM
whiteLT1's Avatar
alright that helps, thanks!
Old Mar 28, 2008 | 08:22 PM
PWR-TRIP's Avatar
I just got mine installed last week and what a difference.
Old Mar 28, 2008 | 09:27 PM
whiteLT1's Avatar
sweet! were they very hard to install?
Old Mar 28, 2008 | 09:56 PM
dangalla's Avatar
yeah i am happy with mine also, i do have some rust on the collectors but other than that no problems with them and like stated the price was right and they get the job done
Old Mar 28, 2008 | 10:34 PM
ricehammer's Avatar
I've had Pacesetter LT's for a year and no rust yet. The quality was actually very good. Yes they are a pain to install, as are all LT's. Here are a couple of links explaining how to do it.
http://www.z28.com/forum/showthread.php?t=116454
http://www.z28.com/forum/showthread.php?t=100225
Old Mar 28, 2008 | 10:57 PM
whiteLT1's Avatar
thanks a lot. will the Y pipe fit up to where the cat should be?
Old Mar 29, 2008 | 06:43 AM
blownbird01's Avatar
I got them and I thought they were the easiest header I've ever installed. Didnt even have to pull the motor off its mounts. I've installed two sets now and both were pretty good quality. All you have to pull is the oil filter, starter, dip stick, and steering shaft. Just make sure the front of the car is jacked up high so you can slide the headers in.
Old Mar 29, 2008 | 07:44 AM
2000GTP's Avatar
What year is your car?
Old Mar 29, 2008 | 09:35 AM
whiteLT1's Avatar
its a 95
Old Mar 29, 2008 | 10:29 AM
2000GTP's Avatar
The y-pipe for the Pacesetter long tubes will change the placement of the cat by quite a bit. Do you have to pass a sniffer test?
Old Mar 29, 2008 | 10:52 AM
whiteLT1's Avatar
nope i dont have a cat either
