ORY pipe for PS LTs ??
Old Apr 2, 2008 | 04:38 PM
LJM97Z's Avatar
I'm getting ready to order my headers tomorrow, also looking to get the ORY pipe too, but it looks like the picture shows more of an exit in the middle of the pipe, will the ORY pipe work with my existing Cat back system, or will the main pipe on the ORY not be in line with my existing I pipe? If this makes sence. its the Magnaflow catback system with a 3" I pipe
Old Apr 2, 2008 | 05:50 PM
2000GTP's Avatar
The i-pipe on my Magnaflow lined right up with the Pacesetter ORY. I clamped the two together with a band clamp.
Old Apr 2, 2008 | 05:59 PM
LJM97Z's Avatar
Cool, looks like i'm in business then, i called PS, they said it should be a direct fit too, man i'll tell ya, those manifolds are a PITA to take off, i'm down to 1 bolt left on the pass manny, got the DR off along with the steering arm, looks like i'm getting close , I can see why these LT1s respond so well to a header up-grade, talk about choked up
Old Apr 2, 2008 | 07:29 PM
2000GTP's Avatar
On the drivers side, you might want to remove the coolant temp sensor from the head so when you install the header, you don't snag and break the plastic connector.
Old Apr 2, 2008 | 08:49 PM
LJM97Z's Avatar
I was looking at that, thamks.
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
greenzee28
Sep 25, 2015 04:29 PM
